"Player is getting power. (It's) making a faint sound and the output jack is flashing but shows nothing on the display"
So, it is obviously NOT 1, 2, or 3 above. It IS getting power.
The first thing I'd try is a re-boot, try unplugging the unit and waiting about
If the Blu-Ray player is not turning on, there's no power and if it's completely dead, there are only three possible cause of the problem:
1. Wall socket.
2. Power cable of the player
3. Power supply unit of the player.
First, try plugging the device in a different wall socket. Avoid using power strip.
Second, check the power cable of the player and replace it if possible. The power cable could be loose and not getting a good contact.
Third, you need to contact a local repair tech to check the power supply unit and board inside the player.
Repairing the power supply unit should not cost too much.
Good luck and have a good day!
Player is getting power. It i smaking a faint sound and the output jack is flashing but shows nothing on the display. Does the device need to be reset? And what else can I try?
The is no power display at my dvd player, what might be a problem?
