see this causes, and fix it. God bless you
If the washer stops mid cycle the timer might
be defective. This part is often misdiagnosed, check other components
before replacing this timer.
f the washer stops mid-cycle the main control board might be defective.
This is not common. Check other causes first such as the lid or door
switch and other components
f the washer stops mid cycle the water inlet valve cold water side may
have failed. Most washers have a cold water rinse and so if they can't
fill with cold water they just sit indefinitely waiting for the cold
water to enter. If there is cold water to the water inlet valve and the
cold water works in other parts of the cycle - or to make warm water -
the valve is not the problem.
If the washer stops mid cycle the door lock assembly should be checked.
The door lock can fail either mechanically or electrically. Test any
switches on the door lock with an Ohm meter. The switches should have
continuity according to their design
If the washer stops mid cycle the lid switch assembly might be
defective. This is a very common problem. The lid switch assembly can
fail either mechanically or electrically. Test any electrical switches
with an Ohm meter for continuity. The switches should have continuity
according to their design.
water is leaking from the back of machine
water leaking from back of machine
