When you turn on tv ,first got a good color then few minutes color start fading .What is the problem .T-con or the Power supply
SOURCE: Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
SOURCE: samsung plasma HPR4272 that had a 4" black vertical line on
There are at least two issues here. First you have bad buffer boards. Second Very possibly a bad X-Main bd and P-Logic bds. Have a trained Samsung tech troubleshoot the set.
SOURCE: Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
SOURCE: Turn on Samsung LN-T4665F and vertical colored
when I turn the modelLN-T4661F TV on it just clicks and clicks any help how to fix it.
SOURCE: 1 vertical black line on samsung plasma tv on left side (model # pn50a450p1dxza)
Visit the site named 'Electro-help' for more
details. Check this link and select the
site named above. View it in 'Flip card' option, which can be
selected from the drop down box menu by the [Sidebar] tag, at the left top left
corner of the display window. It will make search easy. Some times, the ads
attached with each posts both at the right and bottom, might help you to find
the availability of spare parts. There are more than 640 posts to different
brand TVs now. Will be updated daily. Faults to Samaung Plasma TVs are given in detail.
