Im buying this anntenna formy new tv toimprove digtal rereccption
SOURCE: hi i have a granny
All you need is a Wireless Signal Booster antenna
That Will FIX it it is a FIXYA for this problem :)
SOURCE: Has anyone figured out IF such a digital anntenna exist yet?
You don't need a digital antenna; any indoor UHF/VHF antenna will work. The antenna and the TV both connect to the converter box, not to each other.
A standard
rabbit ears (UHF/VHF) antenna with flat wire (300 ohm) connections can be hooked up to the coaxial cable that goes to the Antenna (RF in) jack on the converter box by using a balun (Radio Shack catalog # 15-1297, about $8). If you have an antenna with coaxial cable already attached, you don't need the balun.
To connect the TV to the converter box, you need an adapter that has an F jack on one end and a
1/8" plug on the other (Radio Shack catalog # 278-257, about $5). The
1/8" plug on the adapter goes in the external antenna jack on the TV, and
the other end connects to the coaxial cable that goes to the TV (RF out) jack
on the converter box.
SOURCE: do you need a digtal box converter to pick up tv
Yes this is an analog TV. Please leave feed back if this helps
SOURCE: KDF-60XS955 digital anntenna connection
look for a coax cable connection on the back of your tv, connect antenna to booster, booster to tv, then in the set-up menu of tv, go to channel set-up, scan for channels
