You can download a Samsung Remote Control App, I'll keep looking for a solution, I have an identical TV but I swear I don't think it has a power button. Plug in a HDMI, Aux, or USB device and see what happens. The apps for your phone that covtrol the tv are great, especially if you gave a Samsung phone, if not no worries as I have an iPhone personally.
Your Samsung main logic board is beginning to fail, it would be best to seek a Technician of who can locate a replacement main logic board. When the light flashes it usually is indicating a “Trouble/Error Code” you can look up the error code, if you count the amount of times is flashes then pauses and begins to flash again, that number of flashes is the error code. When the red light is flashing/flickering there is no means to turn the tv “on” simple because the tv is experieicing a component failure. Good luck I hope everything works out for you!
SOURCE: samsung plasma tv
Samsung codes for sky reomte
0060
065, 584, 037, 245, 476, 398, 516, 292, 318,
037
Click here for the link
SOURCE: TV not switching on
Can you hear the sound of turning on?
I think that you need to replace the main board.
SOURCE: hi i have a magnavox 42" plasma TV (model
I'd look for the manual and see what it says about that red light. I can't find squat for "Magnavox KM42010P".
SOURCE: virgin remote control code for volume on my 50" samsung plasma tv
To set up the volume control on your Telewest remote control, to be able to change the TV volume, please follow the instructions below.
1. Using the table below find your make of TV and the code which matches it.
2. Press and hold down Volume + and mute on your remote control at the same time for at least three seconds, until the green light in the top right-hand corner of your remote control flashes twice.
3. Release the buttons and enter the first four digit code from the table below. (You must do this within ten seconds).
4. As you enter the first three digits the green light on your remote control will give a short blink.
5. As you enter the fourth digit, the green light will flash twice to confirm that the volume is set.
If setting the volume is not successful, please repeat the above steps with the second or third codes from the table below.
Samsung 0065, 0584, 0037
065 584 615 037 245 476 516 292 318 236 398 244 100 118 060 088
646
672
642
Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
