The main board and the power supply is bad for your TV and it would be more easier to buy a new TV than to try and fix the current TV that you have and that our TV could of had died on you.
To check it, the best way is use a LED tester, if you do not have one, you have to disassembly the LCD panel, unplug the cable between the power supply & the main board, apply the AC power to the TV, you will see the defective strips do not light up.
I saw a similar problem reported on "fixya" for LED monitors that suggested looking at the capacitors on the circuit board to see if they have erupted or popped. The capacitors look like little cylinders and if failed, their three flaps on the top will open up slightly. Replace the capacitors in this case. If too difficult to solder them, might have to replace the whole strip containing them.
1. Disconnect the cable between the main power supply & main board, supply AC to the TV, if the LED strips are OK, it should light UP, if not replaced all of the LED strips.
2. If the back lights light up, but no display or sound, replaced the main board.(after you re-connect cable).
You have at least one bad LED in the panel and its shutting down the power supply...for future reference a bad Tcon will not cause loss of sound only affects picture
You're a technician work to earn I assume. Do understand; this is a forum to help one who knows a little; to make their sets right. Not a help you like people to turn revenue out of it. Understand? Do not know nothing; yet runs a service shop to cheat others!!!!! https://electronicshelponline.blogspot.com/
