SOURCE: Washing machine does not drain
does the water pour out when you put the drain hose close to the ground if it does then make sure your pump isnt blocked if it isnt then youll need to replace the pump most pumps have 3 little fins in them if you can stop those fins with a screw driver when pump is going then it deffinatley needs replacing as you cannot fix them sorry for the bad news m8
SOURCE: Washing machine will not aggitate.
if it fills with water then stops check you lid or door switch. will the unit drain or spin if so the the timer may be bad
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: My Whirlpool Washing Machine will
the solenoid that controls agitator is the problem it's on the rocker arm one is spin and pump other is agitator
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
