SOURCE: AEG Lavamat 1000
hi
dont know if this is the one you need AEG 1000 Washing Machine
you may need to scrool down to download the manual .
riz.
SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
SOURCE: How do i re set an EFO code on an AEG LAVAMAT
you just need to mop up the water inside the cabinet to allow the float switch in the base to reset.check there is nothing stopping the float returning to the floor. a small leak from the door seal can cause enough of a leak to trip it . clean the door glass and seal to stop this. or change the door seal.
