20 Most Recent AEG Lavamat 88840 Front Load Washer Questions & Answers
3answers
How do I reset the EFO Aqua Control system?
Thanks Guest! It worked perfectly lifting the face of your machine by 45 degrees
The washing machine was full of powder (this was the cause)
7/2/2018 7:40:42 AM • AEG Lavamat... • Answered on Jul 02, 2018
AEG Lavamat washing macine C9 error code
C9 is a motor fault. Normally it's worn out carbon brushes so you'll need to check them first. If worn out or broken, replace them. Then, you need to erase the code (reset the machine). To do this, turn the dial to off. Press and hold together, prewash and soaking buttons. While holding them, turn the dial 1 click anti clockwise. Release the buttons. Turn the dial to off, to any program and back to off. This should get rid of the C9 code. It will come back if you don't repair the motor fault.
12/16/2017 7:01:09 AM • AEG Lavamat... • Answered on Dec 16, 2017
Describe your AEG Lavamat 60210 Front Load Washer
We have AEG lavamat 60210 front load washer and we get E60 code after 1 min. of washing. What is the problem with the machine?
10/23/2016 3:14:33 AM • AEG Lavamat... • Answered on Oct 23, 2016
What means error code "C9" ? AEG Lavamat 74652
C9Motor tacho fault •Check main drive motor •Check tacho magnet •Check tacho coil •Check module
12/22/2015 7:39:53 AM • AEG Lavamat... • Answered on Dec 22, 2015
2answers
Aeg oko lawamat
c9 means the motor is not turning the drum. check carbon brushes in the motor.
10/30/2015 8:15:27 AM • AEG Lavamat... • Answered on Oct 30, 2015
Why AEG Lavamat 88840 Front Load Washer doesn't spin?
either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
5/23/2015 4:31:44 AM • AEG Lavamat... • Answered on May 23, 2015
2answers
Anti-flodd Aqua Control
exact same problem here, we had power cut and after power came on the pump was continuously running with error EF3 showing. This has happened before - design error with AEG
1/23/2015 10:50:37 PM • AEG Lavamat... • Answered on Jan 23, 2015
3answers
White streaks on dark clothes after washing.
Reduce the load !!
You are getting white streaks because the clothes are so compressed the machine is not agitating them correctly.
My daughter gets the same problem and she still insists on packing the clothes in.
My wife washes the same clothes for her with the right load and they come out fine
7/2/2014 7:38:15 PM • AEG Lavamat... • Answered on Jul 02, 2014
0answers
0answers
0answers
AEG Lavamat 88840 Front Load Washer Logo
133 questions posted
Top AEG Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • AEG Washing Machines
Most Popular Question
anti flodd aqua control
  • Washing Machines
