SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
SOURCE: What is m2 code how cani reset in Konica Minolta
This is to display the count of the supplies life counter.
When the counter is reached to 0 life 1 will be detected and maintenance call M2 will be appeared.
The initial value is 40,000, and the countdown system is used.
Use Setting/Procedure
- To clear the count, use [CLEAR DATA] of the Service Mode.
SOURCE: konica minolta bizhub 164 showing M2 maintanaince call
You need to replace 1st the consumables before simulation/reset to prevent further damage to Bizhub 164.
SOURCE: konica minolta bizub 164 call service c3451 tell how solve
Warming-up failure
1 Check the fusing unit for correct installation. 2 Check the open/close operation of the right door. 3 Check the fusing unit, DCPU and PRCB for proper connection and correct or change as necessary. 4 Change fusing unit. 5 Change PRCB. 6 Change DCPU.
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
