SOURCE: My new 26 18 spd Alpine Bike gears are not
Turn the bike over so its sitting on the seat & bars..
There are a few small setting srews on the derailleur..
These are for adjuting.. Adjust while turning the peddles & shifting.. You should be able to smooth it out
SOURCE: 18 speed bike 6 gear shift works fine 3 gear
If the cable is rusty or otherwise binding it won't let the derailleur fall toward the smaller sprockets when the control is moved. Likewise, it may not even let you move the control in the direction that pulls the cable (bigger rings).
If you don't know much about the process I suggest you read this:
http://coachlevi.com/cycling/complete-beginner-guide-to-bicycle-gears-shifting/
and take the bike to a Local Bike Shop for a look-see and maybe a tune-up.
You have to look if when you act on the shifting level it get hard to move or it is free, if free, probably the cable is broken.
Also check if the cable is not too loose, try to follow the cable track and move the level and see if the cable move with that, in that way probably can find where the cable is stuck or broken/loose.
SOURCE: Need to adjust the gears on 18 speed Next
Since you don't specify the make or model a manual is not likely to be recommended for you. However, gears adjustments are sort of generic within limits. Try this link and find your shifters...
http://parktool.com/repair/byregion.asp?catid=53
SOURCE: Cannot send comments to your guy to get specific info I requested
The manual that comes with the bike is a general one, I sell 5000+ bikes a year and can tell you that what you are asking for is not available. Giant, Trek, Cannondale, and the highter price bikes are only sold through bike shops, assembled professionally. You cannot buy them in a box, so your bike is already adjusted for you. You can go to any bike shop and they will verify what I am telling you. Now, what is the problem that you need the manual to answer?
