20 Most Recent
Mountain Shimano Altus Front Bike Derailleur Bicycle Part 78 Questions & Answers
I bought a mountain bike with Shimano Altus gears
There are a couple of possible problems. You can try backing off the cable tension a little bit at the shifter and running back and forth through the gears adjusting as you go till it hits 2nd coming down.You can also try backing off the High limit screw on the derailleur. This will allow the shift to start a little farther from the bike hopefully hit 2nd. Hope this helps.
Shimano Altus gears
The old lubricant has gummed up. It needs a good cleaning and relubrication.
STI shifters gum up after years of use. I've had good luck with this method and since it's nearly free it's probably worth a shot--
"Get a can of WD-40 or a similar light solvent/oil solution. Pull the brake lever back to the bar to partially expose the shifting mechanism and generously hose down the interior with your solvent. I mean really get it in there from all directions, using the little red spray tube if possible. Let it sit for a while and then drizzle in some light oil like Tri-Flo or similar. Then wipe down the exterior of the shifter with some Simple Green or other degreaser (to keep the overspray off your hands).
"I've rescued two sets of STI-type shifters with this method. Hope you get your problem solved one way or another, because new Dura-Ace sure ain't cheap."
source: http://www.bikeforums.net/archive/index.php/t-83743.html
What size is my bottom bracket for a Nishiki Kinzua 29 Men's Mountain Bike
hi if i remember correctly to size up for a bottom bracket, flip your bike upside down resting on handle bars and seat carefully not to damage anything, and where the bottom bracket go's through the frame of the bike you take a tape measure and measure the width of only the frame housing where the bottom bracket go's into this is a lot easier to do when the crank arms are removed. also on some bottom brackets when removed from the bike has all the data stamped on it depending on the type of bottom bracket. if not measure the width of the frame where the bottom bracket sits in too and that will be the size of the bottom bracket you need, then determine which type it is once you have remove the cranks arm which are attached to the bottom bracket could be splined drive or square tapered type bottom bracket basically the shape of the metal part that the crank arms push and bolt on to then match up on a cycle part website.
I need disconnect front wheel mountain bike forfringe super cycle 550 zoom full suspension
The front wheel is normally held in with one of two common methods. A basic nut on each end of the axle or a 'skewer' pin. On most bike that do not have disc brakes you might need to unhook the brake arms to allow the tyre to clear the brake pads.
For the nut type simply slacken the nuts and drop the wheel out of the C shaped notches the axle sits in.
The skewer type is a small lever on one side you swing all the way over then slacken the nut on the opposite side two or three turns. The wheel should then drop down and out.
Need an owners manual for a 26” Women’s Nishiki Pueblo Mountain Bike
That bike was made from 1993-1998. It's a standard Cro-Moly (i.e. Steel) non-suspension mtn bike. In other words, there is nothing unique about it that would require an owner's manual. I might suggest you post the actual issue with the bike to get some feedback as to how to deal with it.
