Dryers Logo
Rufus Chin Posted on Sep 19, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The fan is installed 3 yrs now and spin slowly 897F sku#243 Why
It is 6 from the ceiling so can hardly read the info all I can make out are some # S #000310 897F sku#243 installed three years and only spin slowly 72 ceiling fan
Fan Fair Of Boca
Level 3:
Genius:
  • Master 1,617 Answers
  • Posted on Sep 21, 2015
Fan Fair Of Boca
Master
Level 3:
Genius:
Answers
1617
Questions
Helped
550318
Points
4041
Check the capacitor.
3answers
3helpful
2answers
How to install it
Hard to really tell in the video, but it looks like the fan has a light as well as the fan? Often, the blue wire goes through the housing to power an optional light attachment. Normally, you would have 2 "hot" wires in the ceiling that go to separate switches so you can do them independently. If you don't have the light attachment, you should be fine taping it off and leaving it in the housing.
If you have the light attachment, you would be best to gang the blue and black together to the white (odd if in the US) "hot" in the ceiling. The white in the fan goes to white to the ceiling and green from the ceiling should go on a green screw on the fan (or anywhere you can ground)
The fan will always be on and you can use the pull strings to control the fan and or light (if exists).
Be very careful hooking up the hot with the fan blades attached. It's best to take them off, otherwise if the pullcord is on, the thing starts spinning like mad while you are up there on a ladder
Mar 26, 2013 • Dryers
2helpful
Where can I purchase a 3/4" downrod coupler for a
From your friendly neighborhood electrician - any electric supply (a business supplying parts to
the electrical & HVAC trade) will either carry Hunter parts, or at the very least be able to
order the parts - why: Hunter is manufactered in the USA. Nearly every other brand of ceiling
fan you'll find at your neighborhood Home Depot or Lowes is manufactured in China.
The typical ceiling fan will come with parts for two configurations: (1) flush, and (2) a optional
3-inch downrod, but commercial installations will somtimes use extended downrods.
The Hunter web site (http://www.hunterfan.com) catalog shows available downrods in several
lengths: 12", 18", 24", 36", 48", 60", and 72".
I found Hunter downrod specifics in the online "core products catalog," at:
http://s7d5.scene7.com/s7/brochure/flash_brochure.jsp?company=HunterFan&sku=Core_2011_Trade_Final&config=HunterFan/skin&locale=en&zoomheight=600&zoomwidth=800
I have a Hampton Bay ceiling fan/lamp where the lamp dome is apparently very tight into the housing. I pressed up and turned in the direction noted to remove the dome. The dome houseing came down and is...
Most light domes twist on or off or have thumb screws to loosen and lower the dome.It sounds like you removed the light kit assembly instead of the dome.Try to put back by twisting in place the light kit assembly and look for screws,or hold back on trim and turn just glass dome do not use too much force .I checked web site but can't find your model.It is unusual to not be able to just remove glass dome.Look closely at how the glass dome is positioned. If no screws are visible either the glass part unscrews or the ring unscrews allowing glass dome to be removed.Good Luck.I have installed many ceiling fans the problem is if you didn't install it your at a disadvantage.GOOD LUCK.
17helpful
3answers
The ceiling fan spin was slow. The c61 e185116
Hi, replacement capacitor can be found at amazon. Take a look here: Amazon com c61 capacitor 4 wire. I hope this was helpful. cheers
1helpful
Hampton Bay Deluxe Ceiling Fan SKU: 293972 Never got any but high speed. receiver # as-cf118??remote has 3 speeds. What is wrong?
you need a new remote and receiver. mine did the same thing after a few months an then it completely burntout in 2 yrs
2helpful
2answers
Ceiling fan wiring Aloha ceiling Fan Model # 29079
I have an Aloha Breeze L-Style 52" Ceiling Fan(Polished Brass), Model # 29079 Bought From Wal-Mart about 1 1/2 years ago and the fan speed switch busted and the capacitor melted. I have a new switch but can't find a new capacitor because I can't read the spec info. Looking for a place to obtain the correct capacitor for this fan so I can make necessary repairs!
3helpful
3answers
Can't figure out how to reverse the Hampton fan with the remote
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30 Watt Circline bulb and the remote.
Hampton Bay Windward II Ceiling Fan SKU 523-127 was sold by Home Depot, and manufactured by King of Fans.
King of Fans website is: http://www.kingoffans.com
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan picture, then you will be able to click on Download Owner's Guide.
Mar 11, 2009 • Dryers
2helpful
3answers
Hampton Bay Fan 55295 remote control
I have the Hampton Bay Windward II Ceiling Fan SKU 523-127. I have replaced various parts over the years including the ballast, light shade, 9" 30-Watt Circline bulb and the remote.
This fan can be seen by clicking on Products --> Ceiling Fans --> Click on page 9 (at the bottom of the webpage) then click on the Windward II fan you will be able to get to the needed additional information.
After downloading and reviewing my fan's Owner's Guide, and reviewing the online FAQs, I called 1-800-330-3267, concisely described the problem, and ordered the parts needed with only the fan name and SKU.
I and am about to order more parts after suffering a power surge (The needed info was in the FAQs). My experience is great customer service and speedy delivery of the needed parts.
One of their FAQ's answers the question:
Where can I get parts for my ceiling fan?
You may call customer service at 1-800-330-3267 on Monday through Friday EST. When you call please have your UPC code available. If you do not have your owners manual, you may look on the top of the fan where you will see a silver or gold sticker. There you will find a UL number beginning with the letter E and located under the UL number is the UPC code. The UPC code consists of 12 numerical digits. From that information, the customer service representative will be able to determine if you are calling the correct company and determine the make and model of your product. If it is determined you are calling the wrong company, you will be given the correct number to call.
Top Dryers Experts
john h
