20 Most Recent Dyson AM08 Pedestal Fan Questions & Answers
manual
My power flash off & back on, now I have an F6 error, how do i fix / reset it? Thanks
Hi Dana, it's Jack at Dyson. I'm sorry to hear you're having difficulty with your Dyson Cool AM08 Pedestal fan. If your machine displays an F6 error code I would strongly encourage you to contact Dyson directly, as we will need to provide further assistance to help you to resolve this. When you have your machine easily to hand, please contact the Dyson Customer Helpline on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). Our experts will be happy to take some additional details and advise you of your options. We'll look forward to speaking with you.
6/2/2015 9:37:31 AM • Dyson AM08... • Answered on Jun 02, 2015
How do I fix F2 error on Dyson AM08 Pedestal Cooling Fan
To fix the F2 error on the Dyson AM08 Pedestal Cooling Fan, you must try resetting the fan by unplugging it from the power source for 2 to 3 minutes and then plugging it back in , it can work properly.
6/21/2023 5:42:40 PM • Dyson Dryers • Answered on Jun 21, 2023
C1 error code on dyson pure hot+cool
The C1 error code on the Dyson Pure Hot+Cool indicates a communication issue between the control board and the motor. Here are a few steps you can take to try and resolve the issue:
  1. Turn off and unplug the machine for at least 10 seconds, then plug it back in and turn it on again. This can sometimes reset the control board and resolve the issue.
  2. Check the filter and make sure it is clean. A dirty filter can cause the machine to overheat, which can trigger the C1 error code.
  3. Check the air intake and make sure it is not blocked. If the air intake is blocked, the machine may not be able to cool properly, which can cause the C1 error code.
  4. If none of the above steps resolve the issue, the problem may be with the control board or motor. In this case, it is recommended to contact Dyson's customer support for further assistance. They may be able to help you diagnose and resolve the issue, or recommend repair options if necessary.
2/27/2023 11:35:12 PM • Dyson Dryers • Answered on Feb 27, 2023
H2 error code on Dyson hot/cold fan unit.
what is the question?
7/10/2021 10:18:43 AM • Dyson Dryers • Answered on Jul 10, 2021
Dyson Am04 model no longer turns on due to a power surge. What part is required to fix it? TIA.
First thing is to check the wall socket. Use a desk lamp or something similar and plug it into the socket you use for the heater. If the lamp works so does the socket. Next check the fuse. UK machine have a fuse in the plug, other countries use different systems. If all these check out OK the surge may have damaged a circuit board inside the heater. Only a Dyson specialist could help you with that.
8/17/2020 3:11:16 PM • Dyson Dryers • Answered on Aug 17, 2020
DYSON AM08 PEDESTAL FAN HAS OPERATED FLAWLESSLY FOR TWO YEARS ! TODAY I STARTED IT , IT RAN AS USUAL THEN QUIT AFTER A MINUTE. I TRIED AND SEARCHED FOR A CAUSE FOR AN HOUR FOUND NOTHING UNUSUAL. WHAT COULD BE WRONG?
Probably the bearings are dry. remove the fan and housing to get to the shaft and oil it. The circuit breaker is shutting it off because it is drawing excessive current.
9/24/2019 8:58:41 AM • Dyson Dryers • Answered on Sep 24, 2019
My dyson hot and cold fan is displaying code C2 and won't turn on or off
quote from amazon site***Mine also showed H2. I had a suspicion that it was the remote causing it. Changed the remote battery (CR 2032), turned on the heater and let it circulate for 3 minutes, then I went and tested all remote buttons. It worked! No more H2 error code! Amazon Customer · September 11, 2018
8/30/2019 6:28:22 AM • Dyson Dryers • Answered on Aug 30, 2019
How to detach Dyson Pedestal AM08 fan?
Call Dyson support, I do not have this answer and a search rendered no results
DYSON USA SUPPORT
Call us at 1-866-693-9766
8/2/2018 10:12:47 PM • Dyson Dryers • Answered on Aug 02, 2018
My dyson heater-fan shows a E8. What should I do?
7/5/2018 1:16:01 PM • Dyson Dryers • Answered on Jul 05, 2018
What size battery do I need for the dyson hot and cool heater remote?
Open the battery access panel and if no batteries are present, look in side of battery holder and the size/type is usually stamped in the cradle. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
10/20/2017 2:26:56 PM • Dyson Dryers • Answered on Oct 20, 2017
Dyson AM08 Pedestal Fan Logo
1 questions posted
Top Dyson Dryers Experts
NOEL
NOEL
john h
ADMIN Andrew
ADMIN Andrew
Are you a Dyson Dryer Expert? Answer questions, earn points and help others
View Most Popular
Dyson Dryers
  • Dyson Dryers
Most Popular Question
power flash off back now f6 error
  • Dryers
