20 Most Recent Westinghouse Turbo Swirl 78145 Ceiling Fan Questions & Answers
2answers
Trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
11/26/2023 1:27:41 AM • Westinghouse... • Answered on Nov 26, 2023
12answers
3 speed fan switch
Zing Ear ze208s switches are NOT all the same - the actual switch wafer on the back varies significantly. Some are single-pole making contact with 1, 2, 3 one at a time, others make contact in combinations. Like L123 for high, L1&2 for medium, and L1&3 for low. The number stamped in the center of the back may indicate the difference. I have one with a "4" that is one-pole at a time, and another that is a "21" and makes multiple contacts at a time.
6/24/2017 10:54:20 PM • Westinghouse... • Answered on Jun 24, 2017
2answers
Bulb replacement 0 how do you get the glass cover
Les:
The globe is held on by three metal tension clips holding the globe to the base. To remove the globe, you need to pull down on the globe gently but firmly. Try pulling down on one side and then the other, sort of "wiggling" the globe off. Getting the globe back on can be a bit of a challenge, calling for you to get all three clips aligned in place before pushing the globe back up. A little patience and the job will go smoothly.
Hope this helps. If it does, please leave feedback! That is the only way I know if I am being of assistance or just wasting my time.
1/13/2015 7:59:39 PM • Westinghouse... • Answered on Jan 13, 2015
Hook up remote
If it didn't come with a remote, then YES.
10/10/2013 2:16:24 PM • Westinghouse... • Answered on Oct 10, 2013
How do i change the bulb on a Westinghouse Square
Just twist the glass off. You might have to spray WD-40 around the rim.
7/31/2013 11:58:01 AM • Westinghouse... • Answered on Jul 31, 2013
Trying to replace burned out
Here is a link to another expert's solution. Just click on the highlighted text with your cursor.
http://www.fixya.com/support/t3156249-bulb_replacement_0_get_glass_cover
Please credit him by clicking on his 4 Thumbs Up rating icon if it was helpful.
Thank you.
Joe.
2/17/2011 3:29:35 AM • Westinghouse... • Answered on Feb 17, 2011
How do you change the
there are usually screws that are around the top of the globe or you have to twist the globe gently.
1/1/2011 10:45:27 PM • Westinghouse... • Answered on Jan 01, 2011
How do I get the glass off to change a burned out
well most are just twisted on there or there is nales on each side could be 2-4 nales. BUT IF ITS TWISTED ONE YOU TWIST THE RIGHT WAY BECAUSE YOU CAN BREAK IT.
11/29/2010 6:24:42 AM • Westinghouse... • Answered on Nov 29, 2010
I broke the glass of
The only way is to get in touch with Westinghouse , contact them through their website and post your query or take the details of the office near to your area, call and confirm.<br /> please on the site :http://www.westinghouselighting.com/<br /> hope I could help
8/29/2010 2:22:26 AM • Westinghouse... • Answered on Aug 29, 2010
Replacing 3-speed fan swith, using westinghouse
the third wire should be for neutral (White) This is an incomplete request,
Is this a three wire pull switch or are you hooking up to a light switch on the wall.
but what I know is Black hot
Red switch
white neutral
If it is NOT WHITE do not attach it untill you have someone over to help you
7/22/2010 4:44:46 PM • Westinghouse... • Answered on Jul 22, 2010
2answers
The globe turns but not screw out. How do I
7/15/2010 5:29:37 PM • Westinghouse... • Answered on Jul 15, 2010
Westinghouse Turbo Swirl 78145 Ceiling Fan Logo
Popular Tags
37 questions posted
Top Westinghouse Dryers Experts
Paul Bade
john h
ADMIN Andrew
ADMIN Andrew
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
View Most Popular
Westinghouse Dryers
  • Westinghouse Dryers
Most Popular Question
trying replace burned out
  • Dryers
