Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Parts such as fuser lamp, thermistor and thermostat
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: error CO500
On the right side of cotrol panel there is small hole press it with clips .On the screen appear small dot press it then press 3 then apear screen chose from it troble reset .
SOURCE: I have a konica 7218 with a co500 error
Hello sir; Just need you to reset, turn power off thenhold down "stop" key while you turn on the power.
SOURCE: sir my problem is start machine in warm up
The fusing unit malfunction code.Clean and measurement the continuity of the heater lamp,thermistor and thermofuse.To reset press the service button.Please tell me the copier model for more information.
