Bosch Logixx Front Loader Error E23 clothes stuck stopping door from opening. How can I get the door open?
SOURCE: whirlpool front loader door locked
My followup work-around: I unplugged the machine and drained the water out of the machine. Apparently there is a "lockout" safety feature that refuses to open the door when there is a certain amount of water in the machine. After draining the majority of the water out, I then cleaned the filter (and more water came out- have the bucket and towels ready!). The ultimate problem was that the pump was shot. While reseaching my own records, I discovered that I had purchased an extended warranty for the first and only time because LG was new to making washers. The pump was replaced at no cost within 24 hours.
SOURCE: Bosch washing machine logixx 8 front loader error
I forbindelse med start af vaskeprogram melder maskinenen F37 fejl? hvad betyder det?
SOURCE: Hi, my front loader washing
Hello, welcome to FixYa.
The Key symbol means the lock has been activated some how.
On most bosch of your class this is how you work it on & off.
Here`s how to deactivate it...
1) Press the "menu" button until you see "CHILD LOCK :ON" appear in the display. ( if nothing is pressed within 10 sec.following this the menu will close and it will default to program in the display )
2) Once you see what I just mentioned in the display press the "select" button until "CHILD LOCK :OFF" appears in the display.
3) Finally by pressing the "start/pause" button the key symbol should disappear confirming you have successfully exited the child lock program.
Let me know if this was helpful to you or not, if so please take a second and rate it accordingly.
Thank you for visiting "fixya" for your washer solution inquiry.
good luck going forward.
macmarkus :)
SOURCE: My new bosch logixx front
I just realised that I don't appear to have a comprehensive list of Bosch error codes, but some quick research tells me that F43 is a motor error, usually associated with the motor brushes requiring replacement (Though they may also be sticking and just require removing, cleaning and re-fitting).
SOURCE: bosch front loader washing machine door not opening
The door will not open if the machine detects excess water in it. Run the drain or spin cycle to check if water is being expelled. If necessary check the pump filter for obstructions and the outlet hose for blockages. If this does not work you may have a problem with the pressure system, the door lock itself or a crack or break in the handle and it is not catching the lock mechanism, let me know if this helps or if you need further assistance.
