20 Most Recent Bosch Nexxt Premium WFMC6400UC Front Load Washer Questions & Answers
I would take the water pump ad trip it to clear the rotating shaft of possible cotton threds or other debris stuck in-between the rubber water seals as this can cause a slow dripping of the water as it creeps between the still shaft of the water pump eric
Bosch Nexxt... | Answered on Dec 27, 2017
Either a blocked filter or worn carbon brushes
Bosch Nexxt... | Answered on Oct 11, 2017
if you open the top of washer their should be a schematic taped to the side with all the info you need.
Bosch Nexxt... | Answered on Sep 29, 2017
What error message did you get? Did you research what the error message indicated? How can you make a repair without knowing what is wrong? Makes no sense.
Bosch Nexxt... | Answered on Sep 08, 2017
If it does not drain, then it will not spin.
Locate and clean pump filter.
Bosch Nexxt... | Answered on Dec 03, 2016
I am willing to send you a copy of the manual that covers 4 Nexxt Premium models; I have a PDF.
Bosch Nexxt... | Answered on Oct 30, 2016
This video will show you how to change a door seal on this Bosch WFMC6400UC front loader washing machine
we have all bosch repairs in our channel
You can get seals on eBay
Bosch Nexxt... | Answered on Jul 10, 2016
means that the computer is seeing the door as opened even though it may be closed, you can fix this by following this guide:
Bosch Front Load Washer Error E01
Bosch Nexxt... | Answered on Dec 10, 2015
This is a trouble code for a fill that is taking to long. Make sure that both the hot and cold water valves are turned on. Hope this helps.
Bosch Nexxt... | Answered on Nov 15, 2015
Your water pump is clogged
Bosch Nexxt... | Answered on Sep 06, 2015
Blocked inlet filter or kinked hose
if not then it will be your inlet valve
Bosch Nexxt... | Answered on Jul 12, 2015
LID LOCK LIGHT STAYS ON NO START:
Usually either the lid lock mechanism, the lid lock actuator or the board is the culprit even a disconnected capacitor.
MACHINES SAIDS SENSING
When the START button is pressed, the washer will first perform a self-test on the lid lock mechanism. You will hear a click, the basket will make a slight turn, and the lid will unlock briefly before locking again. Once the lid has locked the second time, the washer
will slowly spin the dry load to estimate the load size, and begin adding water. The washer will then move the load briefly, pause to allow water to soak in to the load, and resume adding water. This process may repeat until the correct amount of water has been
added for the load. You may also hear water flowing through the dispenser, adding detergent to the load.
NOTE: The sensing light may also come on during the Soak and Wash portions of the cycle. This is normal.
Try unplugging the cord a couple of times. See what happens then try going into diagnostic error codes, see what codes are shown. To pin point where the problem is. if you have no display to read the fault codes. Your main control board may be the issue.
Next, while in Manual diagnostics, try to get the unit to spin; if the motor hums for a split second and then shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors.
This is proof that the shifter/sensor actuator assembly is the issue because the optical sensor is not reading the motor speed.
I suggest unplug the washer and check the wire connections on the switch. If a meter is available then you can check the resistance (ohms) of the lock motor.
Note: After performing the manual test and the lid lock works perfectly, or at least as it is supposed to. You can eliminate that as the problem.If the lock worked in the manual test but doesn't in an actual cycle then I suspect the control board is at fault.
A safety feature found on front load washing machine is the door switch and the door lock and strike. On most models, the door switch must be closed and the door lock must be activated before the washer will start. The switch is normally located in the door frame of the washing machine, but may also be part of the door lock assembly. Inspect the strike to make sure that it engages the door lock assembly and that the door remains closed. To check the door switch for continuity with a multi-meter, you will need to disconnect the power and remove the front panel.
The lid switch on a top load washing machine is a safety device designed to prevent the motor circuit from operating when the lOn some models, the water inlet valve circuit is controlled as well. If the lid switch fails, the washer may not start. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the motor or water valve circuits, then the switch may be defective
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
God is good and that's why I give free advice.
Bosch Nexxt... | Answered on Jun 22, 2015
See the trouble shooting guide at repairclinic.com. Reference model specific info from the self help section. Have your model number with you when you go.
remove the cold water hose from the washer look inside the parts of the washer you unscrewed it from, there is a plastic screen in there that needs to be clean out. you can pop it out with a small flat head screwdriver, clean it then pop it back in. also remove cold hose from valve on wall. there is another screen in there that needs to be cleaned. this will fix the problem
Bosch Nexxt... | Answered on May 27, 2015
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
493 questions posted
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
nexxt premium
  • Washing Machines
