20 Most Recent Bosch Axxis WFL 2060 Front Load Washer Questions & Answers
Water tap closed? what does this mean
Water Inlet Flow Meter P/N 00602819 is failing. For a Bosch Axxis Washer model WFR2460UC -- If both of the water supply valves are open, you cleaned the hose internal strainers, and there are no kinks in the hoses, part "Water Inlet Flow Meter P/N 00602819" is failing. This device measures exactly how much water enters the tub, no matter what the water pressure. Not hard to DIY replace with simple tools.
2/6/2024 5:33:11 AM • Bosch Axxis WFL... • Answered on Feb 06, 2024
3answers
Laundry detergent
Why do you want to use a special detergent??? Tide works fine! You just need to use about 1/4-1/2 what is used in the American machines. Now if you really want some exceptional laundry detergent like we use in Europe, buy Persil (google it).
9/22/2022 11:34:56 AM • Bosch Axxis WFL... • Answered on Sep 22, 2022
Axxis washer beeps instead of starting
Make sure it's plugged into dryer and not the wall
2/1/2022 10:01:16 PM • Bosch Axxis WFL... • Answered on Feb 01, 2022
2answers
Washing instructions
My book says for the Axxis WFL 2050/WFL 2060 : from the left while looking at it from the front: detergent for wash, stain remover, middle: fabric softener, fabric conditioner, right one: detergent for soaking agent. (Do not use chlorice bleach in this wasking machine).
10/1/2019 10:07:22 PM • Bosch Axxis WFL... • Answered on Oct 01, 2019
My Bosch WFR2400UC has a blank display
how work
8/22/2018 11:02:01 AM • Bosch Axxis WFL... • Answered on Aug 22, 2018
3answers
Drum Does Not Turn
The belt that turns the drum has broken.
3/11/2018 6:31:32 PM • Bosch Axxis WFL... • Answered on Mar 11, 2018
What are WFL 2060 fault codes
Bosch WFF washing machine error codes: E1 - The door is not closed and cannot therefore lock. E2 - Washer will not fill with water. E3 - Washing machine not heating. E4 - Washing machine won't empty. E5 - Fault in the motor drive circuit. E6 - Unexpected heating. E7 - NTC thermistor open or short circuit. Please note that the codes for the WFF range of Bosch machines differs from other ranges.
2/3/2018 10:24:15 PM • Bosch Axxis WFL... • Answered on Feb 03, 2018
2answers
Door hinge is broke on Bosch Axxis+ Front loader
There are 4 screws in the door that hold a plastic hinge cover on .The door will then set into the hinge just fine (PLENTY OF ROOM) and then you put the hinge cover back on and screw the screws in to hold the door onto the hinge.You will likely need a 2nd set of hands to keep from breaking the door.
10/10/2017 12:50:05 PM • Bosch Axxis WFL... • Answered on Oct 10, 2017
I have a Bosch model
Follow this link: https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/39-129-562724-/Bosch-Washer-is-making-loud-noise-WFK2401
9/22/2017 3:58:14 AM • Bosch Axxis WFL... • Answered on Sep 22, 2017
Hot water will not stop flowing. Hot water
Sounds like a bad shutoff solenoid. It operates the valve to let water in and then shut it off. There should be a valve behind the machine where the hose connects to the wall so you don't have to isolate hot water to the entire house.
9/18/2017 7:15:26 PM • Bosch Axxis WFL... • Answered on Sep 18, 2017
0answers
0answers
Washer makes a rattling sound when it starts the
Sounds like you cannot activate youre imagination maybe Ill do this for you one time here goes ~: You or someone left coins in your pockets jeans cardigan whatever they got out of garment while in the wash spin and worked themselves into the machine and now its bug-gerred innit?
8/5/2017 8:21:10 AM • Bosch Axxis WFL... • Answered on Aug 05, 2017
Hi, have just purchased a
hi .it might be likely that the coin is stuck in the pump .to access this you need to open the panel at the front and open it panel.see pic.please note that some water will come out when you open it.put a big towel in front.of it.. k-la5imggbuatfaqpqgussyi4e-5-0.png
6/12/2017 6:43:54 AM • Bosch Axxis WFL... • Answered on Jun 12, 2017
Bosch Axxis WFL 2060 Front Load Washer Logo
675 questions posted
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Bosch Washing Machines
Most Popular Question
door hinge broke bosch axxis front
  • Washing Machines
