I am trying to get log with a base but it will not alphaf2 alpha only works with the letters but not for and of the f#s
The TI-84 is a bit of a pain this way. You need to access the logBASE function either through the catalog or the MATH menu. You can't spell the function name as with some other calculators.
Press MATH, scroll down to the logBASE entry, then press ENTER. This will put "logBASE(" into the entry line. You can then enter the arguments and press ENTER to calculate the result. For example, to calculate the log base 2 of 8, press MATH, down-arrow a number of times to logBASE, press ENTER 8 , 2 ENTER. This should give you 3.
SOURCE: How do i calculate the log to a specific Base?
If you have the latest version of the firmware (2.53) you can use the logBASE function available in the CATALOG. If you don't have the latest firmware, you can get it from http://education.ti.com
Regardless of the firmware version, you can always compute the logarithm to any base by using the relationship
logb(x) = log(x)/log(b) = ln(x)/ln(b)
Testimonial: "Perfect answer!"
