20 Most Recent Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Questions & Answers
is the cursor the graphing cursor or the normal typing cursor?
Texas... | Answered Yesterday
Just hit the 2ND key and the 0 (catalog key)scroll down to percentage or just divide the answer by 100.
Please rate this a fixya
Texas... | Answered on Mar 13, 2019
Hi
You can try and clean the I/O port just blow air inside if it will not help you can try to install the Os again , take all 4 batts wait 5 seconds put them back take one batt out press and hold the del key and put back the battery and then press the on button the calac will go off this should rest the calc if it will not help take out 1 batt pres and hold the del put back the batt and connect the calc and try to install the Os i hope it will help
Texas... | Answered on Jan 08, 2019
Sorry, answer was posted as a clarification request.
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
THIS WILL HELP YOU 4 SHO
the best way to get all your applications back is to link your friend's ti-84 plus and make a file backup, ( do this by first installing Ti graphing Product CD wich is included with the calculator) after this just connect your calculator and store the files back onto your calculator! ZOMG??? IS it that easy???
yes it is, just apply some clear thinking and ull be just as smart as i am
Texas... | Answered on Sep 05, 2018
Ok I had this problem all of a sudden and I kinda flipped out, but...I DID FIND A WAY TO FIX IT, all i was hit it against my pillow and bed for like 5 secs and it suddenly worked again. lol its a miracle! But try it and u never know..it worked for me.
( O yea, make sure its on the "Ram Cleared" screen, then beat it against your bed or something soft)
Texas... | Answered on Sep 03, 2018
binomcdf() takes two or three arguments, but you're providing four. The first argument is the number of trials (7 looks good for this), the second argument is the probability (.25 looks good for this), and the optional third argument is the number of successes (2 in your case).
Try binomcdf(7,.25,2)
Texas... | Answered on Aug 13, 2018
Press Y= key, enter the function, then press the Graph key
Texas... | Answered on May 20, 2018
I had the same problem like yours. First, I reset the RAM and then it no longer turned off right away; but it responded extremely slowly. Second, I tried to install the new OS for it, but unsuccessful until I blowed really hard several times into the round connector. After that, the cursor started blinking. Finally, I downloaded the new OS into it and hoped that the problem never happen again.
You go to http://education.ti.com and follow their procedures to reset the RAM.
Texas... | Answered on Oct 14, 2017
You need to change the mode from Math Print to Classic Mode to get the multiple line display. Press Mode to open the correct menu. Use the up/down arrows to make sure that an item in the first line is highlighted (MathPrint or Classic). Use the left/right arrows to select Classic. Press Enter. If you see a line labeled Save, use the down arrow to highlight the line and press Enter again.
This is briefly shown in the manual. See page 9 (page 16 of the PDF) for the menu that applies. The section is labeled Setting the Clock. The rest of the details on changing modes is on page 15 (page 22 of the PDF). Texas Instruments has the manual for the TI-84 Plus Silver Edition in their support section. Start here: https://education.ti.com/en/guidebook/search?active=guidebooks . The direct link to the manual is https://education.ti.com/download/en/ed-tech/C4D11EB6D86B47D19CD768E54A967441/6CC4C5AED5004F808892046AD33D4A35/TI84Plus_guidebook_EN.pdf .
I hope this helps.
Texas... | Answered on May 25, 2017
That is what I get with your numbers on the TI84 Plus Silver Edition 0.1870313608. I get the same on the TI83 Plus. What can I say?. Apart from an error entering the numbers ( a 6 for a 9, a 3 for an 8) I cannot think of anything else. Sorry.
Texas... | Answered on May 17, 2017
When you reset the Memory you clear all in the RAM. Recreate your tables. If you do not want to lose something you created, archive it.
Texas... | Answered on May 11, 2017
There are several ways of doing this.
Since you're using a graphing calculator, you can always graph it as a function of 'a' and use the graphical tools.
Another way is to use the solve() function. For example, to find the value of a where the integral of sin(x) from 0 to a equals one, enter
solve(fnInt(sin(X),X,0,A)-1),A,1.5)
solve( and fnInt( are accessible through the CATALOG. The 1.5 is an initial guess.
Texas... | Answered on Dec 27, 2016
See image below
Texas... | Answered on Aug 27, 2016
Shift [x^-1] allows you to access the matrix features. Under Names you select the names you want to use for your matrices. Under Math you access the various commands. Under Edit you edit the contents of your matrices.
Texas... | Answered on Apr 02, 2016
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
1,041 questions posted
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Steve Allison
Steve Allison
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Texas Instruments Office Equipment & Supplies
Most Popular Question
restore applications ti 84 plus
  • Office Equipment & Supplies
