Drum stopped turning following noise on spin
SOURCE: loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
SOURCE: Drum noisy when spinning
main wash bearing fail parts for this £48 if you are mechanicaly minded then its a 3hr job if you have all the tools appliance doctor
SOURCE: kenmore washer
It could possibly be a motor coupler that has broke. Its a small rubber disk mounted on plastic drive joints. Its located between the motor and the transmission. This coupler is made to rip or break in case of something more serious, sort of like protection for the motor or transmission. Jim
SOURCE: drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
SOURCE: wfw8300sw01 - makes loud noise sounds during spin
The bearings have collapesd due to the seal going faulty. If bearings can be accessed to from the outside, it is possible you could do the repair. If big bearing and seal is accessed from the inside, suggest tech. do it as it gets dirty and a lot more complex.
Hi
If its rattling check the drum for anything
caught in it.Washing machine noise is not only annoying, it can also be a sign
of serious damage. When armed with a few tips, you can determine what problem
may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin
cycle. Drum bearing failure is common when the bearing seals start allowing water
to enter. You can take the belt off and spin the drum by hand, and if the drum
rumbles, replace the bearings.
Turn the drum by hand and listen for loud
noises. If the drum itself is split or the 'spider' is corroded, broken or has
come apart from the back of the drum it will create a loud noise on every turn
of the drum. (When the bearings have gone bad, the noise is constant the entire
time the drum is spinning.)
Look for obvious dents and creases in the
drum or look for coins or small objects stuck inside the tub underneath the
drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like
coins or small objects when a noise occurs while the washing machine is
emptying water.
Remove the sump hose and look for bra wires
if you hear a light scraping noise when the drum is turned by hand. You can
also check to make sure a wire isn't poking out of one of the holes in the
drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if
you hear a high pitched squealing noise to check for motor bearing damage or
wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further
query or else please accept the solution.
Thanks for contacting fixya.com
Hi
If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary. Also check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
none of the solutions to other similar problems seem to cover my situation. The noise was suddenly horrendous and there is obviously something that is broken and preventing the drum turning at all. Anyy suggestions whoud be very very welcome. i don't know if htis is fixable or I should just go for a new amchine. I am pretty able with DIY and did replace a washing machine seal on my last machine ancient machine. this one is only 7 years old and young in my book! grateful for any advice. I haven't actually managed ot pull the machine out and have a look in. I intend doing this but need to build up to pulling the kitchern space apart!
