SOURCE: Locked into progressive scan AND Setup is Unavailable
This solution will also work for GoldStar DVR1000! make sure no DVD or tapes are in the player press and hold stop button and it releases you from Progressive scan mode. After searching the web for hours for this model got desperate and was trying fixes for other brands and models, this one worked. Thanks koolanit
SOURCE: SD-K530SU - Turning Off Progressive Scan Mode
Sure that's easy, I read this in the manual:
http://tacpservice.toshiba.com/ConsumerProductSupport/Manual/dvd/SDK530.pdf
(Page 18 - Progressive Scan Section)
All you have to do is:
1. Remove the disc in the DVD/VCR.
2. Press and hold the STOP button for 5 seconds before releasing it. (Note that this is the stop button which is physically on the player.)
And that should pull you out of Progressive Scan Mode.
SOURCE: How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
SOURCE: Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
SOURCE: Not able to turn off Progressive scan feature-sony dvp nc85h
Are you pressing the Progressive Scan button on the front of the Player? You need to look at the BACK of the Player. There is a manual switch just below the words "LINE OUT". This needs to be moved to the left where it says "Normal"
Try this please!
Brian
bought in Vietnam and trying to play in cuba. Can't get the picture to stop rolling and it is off center. I have a progressive scan Sony TV and have set it up on the player but this does not help. Any ideas what to do?
if you can help me, please, send to [email protected].
