20 Most Recent LG DV276 Recorder Questions & Answers
2answers
My dvdsound is very low the remote volume does not work what must i do?
you said that you do have sound but it is very low so thatt suggestttt either the volume is turn down or you need ampified speakers to push the sound or you check the speaker wires as well. One thing that is getting attenion is sound bars with a remote. just a thought.
7/4/2015 1:41:18 AM • LG DV276... • Answered on Jul 04, 2015
I have a LG DVD 276. When I play a CD it always
push the stop button then remove the cd, power off the player and then power it on again then press the eject button and insert the cd it will now start to the main selection.you can now select the play that what you need to select.
3/2/2014 6:14:23 AM • LG DV276... • Answered on Mar 02, 2014
I bought a LG DP132 DVD player today and cannot get it to work
you must check the instruction first in the manual so you can operate the unit .
3/2/2014 6:00:37 AM • LG DV276... • Answered on Mar 02, 2014
Lg dvdwont work after power surge
in most electronic devices there is a small fuss situated in side this could have blown. however if your device is still coverd have the shop repaire it for you
10/1/2011 9:50:18 AM • LG DV276... • Answered on Oct 01, 2011
3answers
Multi Region
This should help you...
Using the remote control open tray
Press 0, 0, 0
Region selection will appear.
Select 0 for no region (ie. all regions)
Press pause button on remote control.
Turn Unit off and back on again.
It should now be region free.
Test your disk.
Thanks
ayan
6/19/2011 2:51:56 PM • LG DV276... • Answered on Jun 19, 2011
0answers
Looking for a replacement remote for an LG DV276.
Try website like Remotes.com to buy an a exact remote as an original remote.
10/28/2010 2:29:58 AM • LG DV276... • Answered on Oct 28, 2010
I NEED THE REGION FREE CODE FOR AN LG DVD PLAYER
This should work
Ensure there is NO disk in the tray first !
Press 0, 0, 0
Test your disk.
9/11/2009 1:01:44 PM • LG DV276... • Answered on Sep 11, 2009
2answers
Need to change region code on dvd player
Check the following:
http://www.videohelp.com/dvdhacks?dvdplayer=DV276&hits=50&Search=Search
Thanks for ranking my solution.
9/7/2009 6:08:43 AM • LG DV276... • Answered on Sep 07, 2009
3answers
Change my LG DVD player to multizone
Thank you .. thank you..
I bought 4 dvd's from the states that wouldn't play in Australia changed the region and it is now playing
thank you so very much
4/24/2009 2:59:40 PM • LG DV276... • Answered on Apr 24, 2009
6answers
LG DVD player LG276
I picked up a LG DV276 DVD Player here in Australia but I am from the United States so I own region 1 DVDs. I unlocked my new player by instead 1. Open the tray. 2. Press 0 0 0 0 on the remote and a Menu will appear. 3. Press 0 for region free. 4. Press pause and power off.
I can play everything now, Aussie and US DVDs. Thanks LJ66.
12/13/2008 8:36:09 AM • LG DV276... • Answered on Dec 13, 2008
Area Code
change the area code in your DVD player setup.
6/29/2008 6:41:12 PM • LG DV276... • Answered on Jun 29, 2008
2answers
Dv276 unlock
LGs are relatively easy to make region free and therefore should be able to play any DVDs. Below is one of the methods:
1. Using the remote control open tray
2. Press 0, 0, 0
3. Region selection will appear.
4. Select 0 for no region (ie. all regions)
5. Press pause button on remote control.
6. Turn Unit off and back on again.
It was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
5/1/2008 1:11:08 AM • LG DV276... • Answered on May 01, 2008
Error message is check region
hi snadfrod
have a look here LG DV276
see if this will help you.
riz.
4/22/2008 9:10:00 PM • LG DV276... • Answered on Apr 22, 2008
0answers
LG DV286
Be the first to answer 3/6/2008 9:42:42 PM • LG DV276... • Posted on Mar 06, 2008Be the first to answer
I have a LG dvd player 5083 inserted the disc the correct way into the draw but the machine does not play the disc a very slight humming noise is heard then it spits the drawer back out
Clean the Lens: Use a DVD cleaning disc to clean the lens. If the problem persists, consider professional cleaning. Test Other Discs: Try playing different DVDs to see if the issue occurs consistently. If it's specific to one disc, that disc might be the problem. Check for Updates: Make sure your DVD player's firmware is updated. Refer to the manufacturer's instructions for firmware updates. Try a Different TV: Connect your DVD player to a different TV to see if the noise disappears. If it does, the issue might be with your TV. The hum is simply the player trying to read the disc. It can't so, it spits it out. Remember that prolonged use of a malfunctioning DVD player could potentially cause damage. If the problem persists, consider seeking professional repair or replacement
4/19/2024 8:46:44 PM • LG Televison &... • Answered on Apr 19, 2024
LG DV276 Recorder Logo
26 questions posted
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
View Most Popular
  • LG Televison & Video
Most Popular Question
cannot unlock lg
  • Televison & Video
