TAPES START TO PLAY THEN THE UNIT SWITCHES OFF SAYING SAVING YOUR SETTINGS
Check any mechanical failure in the vcr unit. like tape won't work properly might some obstruction or plastic broken.
I have just looked at a similar machine RDXV60, with precisely this problem. When playing, rewinding or fast forwarding VHS, the machine is OK for a few seconds and then switches off, but is fine if paused during play. This was due to inadequate pulses from the take-up spool rotation sensor, maybe due to insufficient (IR) light reaching it, or to reduced sensitivity. The problem was fixed by changing the 33K pull-up resistor (R518?) for this sensor to a 75K one. Specialist knowledge is required to correctly and safely carry out this fix. Maybe different for DVR660.
SOURCE: I cannot get it to record a vhs tape to a dvd.
You need a remote to setup the dvd record and vcr record. Then you have to do dvd initialization perhaps before you can dub from tape to dvd?
