20 Most Recent
Toshiba REGZA 47HL167 TV Questions & Answers
Toshiba TV model 50HPX95 does't Boot and the screen only shows the message Booting... . Anybody knows if it is worth paying to fix it?
worth , is personal thing, but boils down to.
what is the cost in shop to fix it, (not cheap)
against a new TV or used,
only you can can answer any question of economics.
you posted TV to computers, and TVs are not. that.
this TV is 13 years old today,
does the TV part work, at all , even on antenna?
That TV has lots of features, do any work at all?
the home screen is dead, (booting is the clue)
so sounds like to me power supply issue inside, making the brain inside dead or its memory banks.
my guess is used, dead, 13 year old TV is only worth $100
for parts.
and tad more working,
I'd upgrade,
Hello sir
My Toshiba LCD model 40CV600E
Problem was no display but sound can still can hear.
i moved you to TV from computers.
can you see the video on the screen with a flash light.??? i bet yes.
all LCD have back lamps. that must work or turn black, or dim
use flashlight first to see data/tv presentations,,
this TV is 9 years old today
this TV has CCFL back lamps (sell it and get LED TV)
here is page 37 in your manual (ive never seen one last 9 years)
quote
The cold cathode ? uorescent lamp used for the back light on this TV has longevity. When
the brightness of the screen comes down,
or the ? ckers of the screen are caused, or
some parts of the screen do not light up,
it may reach the end of its life. Contact a
service technician.
end.
Exact same problem on 47" Regza: multicolored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Toshiba Regza sound but no picture
I had the same problem last night - sound but no picture form any of the inputs - DVD, VCR, FIOS or antenna. I could still see the TV menu. If you go to the TV menu - you can go to the settings (far right top), from there you can choose to restore factory settings, usually needs a code - 0000 (if you did not choose a different one), select yes when prompted if you want to restore factory defaults. This brought my picture back. I lost all of my picture preferences i had set - but at least I got a picture! I hope this helps!!
Marilyn
I LOST THE SCREWS OF MY TABLE TOP STAND OF MY
Read the informations of those screws to tighten the tv and the base stand together.Read it in ur owner manual for those exactly screws sizes.Standard screws tvs sizes for a 46" are screw (M4 X L16).
STUCK IN STANDBY
Maybe the 12v regulator IC die. Replace the 12v regulator IC.
Another thing to try is to replace the signals board. The DIY solution is to resolder a very small IC on the signals board (the board with the scart sockets on it). You will need a very steady hand and a small clean tipped soldering iron.
It wont turn on. What do i do?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
