20 Most Recent
Windchaser Freezer ICM15 Portable Ice Cube Maker - Grey Questions & Answers
My Windchaser ICM12 will not
What I tried is to manly rotate the water trough that has the swing gate & pushed the Stop button. No results. I then tried rotating it back -n-forth several times, unplugged, replugged, posed Start, AND IT WORKED!!!
Can not get it to work
I noticed with this unit you have to remove the water inlet tubing unplug the Low water sensor get some works bathroom toilet cleaner and put it in holding the lowest tubes closed let it work for 1 min then thoroughly wash it inside only and reinstall it the low water sensor has issues with build up causing this unit to stop working after you reinstall it stand the unit upright for 24 hours plug in and set cube size then it should start working like new
I need to replace the
Download this manual there is a toll free number on the front cover.
http://www.yachtsofstuff.com/adgraf/MermaidMFG/Portable_ice_manual.pdf
Water level light on when
The operating processor has some garbage in it do to a small power surge and if you leave the unit unpluged for 40Min, it will reset back to normal.
