20 Most Recent Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Questions & Answers
Frigidaire upright freezer
Hello Susan, thank you for your post! Did your freezer previously experience a power loss? If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to your appliance by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on your freezer. After deactivating the alarm and your freezer has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, your freezer may possibly have a communication problem with the control board, temperature control or a wiring harness. If this is the case, I would recommend connecting with an experienced technician to determine the underlying cause.
6/2/2018 2:37:24 AM • Frigidaire 20.6... • Answered on Jun 02, 2018
The door ajar light and
On electronically controlled units, a light out issue may alert you to a failure situation,(minor).. Replace the bulb and see if that was the fault I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/31/2017 10:34:16 AM • Frigidaire 20.6... • Answered on Dec 31, 2017
I have a freezer model
Normally, laying a refrigerator down will cause any debris or sediment to float through the tubing and eventually end up in the filter drier which contains silica beads to absorb moisture. Debris will then plug up the drier. A technician will be required to evacuate the sealed system. He will then cut out the old drier and braze in a new drier and recharge the system. There is usually no guarantee that this will fix it because if the debris is large, it may clog a capillary tube and render the unit un-repairable. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/16/2017 1:47:59 PM • Frigidaire 20.6... • Answered on Dec 16, 2017
2answers
Freezer not freezing
Hello jannette859,
huuum at your service
You said,
freezer was working fine had to unplug it due to evacuation, now it doesn't freeze, is there any reset buttons? i didn't turn the temp selector to the off position before unplugging
Try turning off the temp. switch off.
Then plug it in and turn the temp on!
this may reset it.
Repeat one more time and let me know ho it went!
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Bless You huuum
Please give me the best rating at fixya .com before you sign off.
Thank You
11/7/2015 2:43:29 AM • Frigidaire 20.6... • Answered on Nov 07, 2015
2answers
Door ajar alarm keeps beeping, ice buildup around inside door
I had this same issue and all repair service could do is stop beeping. Finally I sold my refrigerator for cheap and got a new one.If you don't have the proper equipment to adjust door and seals. better call a repair service and hope they in your case, should help.
8/20/2015 12:26:42 PM • Frigidaire 20.6... • Answered on Aug 20, 2015
Can we leave the wooden pallet on the bottom of freezer?
Hello Rebecca - The styrofoam and wooden pallet attached to the bottom is part of the shipping material and it is recommended to be removed. If you decide to leave it attached it should not cause any damage, however keep in mind that it might trap moisture under the unit and cause corrosion.
7/29/2015 1:43:29 PM • Frigidaire 20.6... • Answered on Jul 29, 2015
Power surge on ffu2065fw2 , what wil it do
Hello friend, thanks for your post! I see that your Frigidaire freezer had a power surge and you're asking what could happen. If your appliance had a power surge it could cause an issue within the board or wiring harnesses. Is your appliance giving any error code or beeping? If so, could you advise what it currently is doing? I look forward to providing you any assistance. -Matt
8/26/2014 6:58:01 PM • Frigidaire 20.6... • Answered on Aug 26, 2014
How do I fix my upright freezer door lock?
Replacement parts are available here. 03 Door Parts for Frigidaire FFU2124DW2
7/30/2014 10:59:51 PM • Frigidaire 20.6... • Answered on Jul 30, 2014
I have a freezer with a door lock I lost the key
http://www.toysrus.com/product/index.jsp?productId=2748356&fromRegistryNumber=44660901&product_skn=897218
7/30/2014 6:39:28 PM • Frigidaire 20.6... • Answered on Jul 30, 2014
When the power is on. error code is off. what is the possible problem?
Hello Friend, this is Z. I am happy to assist you! I see that your question is listed under Frigidaire Upright Freezer; however, please help me understand the issue you are experiencing. Is your freezer showing error code OFF? If so, the temperature control is in the OFF position. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating your freezer by pressing the UP arrow until display shows "4" or desired setting. Please allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I hope these troubleshooting tips help you in some small way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
7/21/2014 11:58:08 AM • Frigidaire 20.6... • Answered on Jul 21, 2014
Why Frigidaire Upright freezer FFU20FC4AW2 compressor starts and stops
Hello Friend, thank you for your question! From what you have described it sounds like the compressor is cycling on when cooling is necessary and cycles off when the temperature inside your freezer has reached the set temperature. This is normal. If you feel that there may be some other issue occurring, feel free to go to the manufacturer website where you can easily locate a service provider in your area.
7/17/2014 8:20:56 PM • Frigidaire 20.6... • Answered on Jul 17, 2014
If freezer motor does not sound continously is it ok
The motor not always a sound and if they do run constantly you will have a fire on your hands. Open the door for 45 seconds and then close it .uu will find the motor kicks in and runs for 1 min to 3 minutes.
6/5/2014 8:31:05 AM • Frigidaire 20.6... • Answered on Jun 05, 2014
Maytag upright freezer will not drain and water will freeze in bottom. How do you repair Model CFU2046ARW
Check your door/'s are sealing if they leak u will get freezing occurring in the bottom and around the door will have allot of condensation. good luck all the best . P's always lay liquid bottle on their side as they will cool quicker and be better on electricity.
6/5/2014 8:23:08 AM • Frigidaire 20.6... • Answered on Jun 05, 2014
Should my green light be on at all times on my freezer and should temp be on normal
My green light stays on all the time unless I open the door and it needs to get back down to temperature. The red light will come on then and return to normal after 30 seconds to a few minutes if on a hot day. Good luck hope I could help
6/5/2014 8:18:38 AM • Frigidaire 20.6... • Answered on Jun 05, 2014
What is the year of manufactured mfu21m3gw1
January 2001 and july 2003 is when it was sold between. Some new old stock is still getting around. Shocking model for faults . But most were easy fix
6/5/2014 8:16:20 AM • Frigidaire 20.6... • Answered on Jun 05, 2014
How long for red light to go off when the door has been open?
3 seconds or as long as it takes to get back to temperature.
6/5/2014 8:10:06 AM • Frigidaire 20.6... • Answered on Jun 05, 2014
Freezer is 11 years old. Alarm has gone on and freezer is not very cold. Has it died or can it be fixed?
Hi there. I really think it could be a thermostat or a small fault. But jump on Google to look for faults with that model. Let me know how you go
6/5/2014 8:05:51 AM • Frigidaire 20.6... • Answered on Jun 05, 2014
Does the green light on my freezer need to be on at all times and temp set to normal
Good Afternoon Friend, I understand that you want to know if the green light has to be on at all times and the temperature set to normal on your Frigidaire freezer, model# FFU2124D. The green light will always be on. This is letting you know that there is power going to your freezer. You do not have to leave to temperatures set on normal. You are able to choose any temperature that works for you and keeps your food frozen. When changing temperature settings, turn the knob slightly in the direction you want, and wait 24 hours for temperatures to stabilize. If you want to change the temperatures more, again wait another 24 hours after changing them, for the temperature to stabilize. Hope this is helpful. -Best Regards- WP
5/29/2014 7:32:19 PM • Frigidaire 20.6... • Answered on May 29, 2014
Frigidaire 20.6 cu. ft. / 583 liter Upright Freezer FFU2124D Logo
179 questions posted
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Freezers
  • Frigidaire Freezers
Most Popular Question
door ajar alarm keeps beeping ice
  • Freezers
