20 Most Recent
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Questions & Answers
Hoshizaki F-450maf has no water in reservoir tank
If the Hoshizaki F-450maf ice machine's reservoir tank has no water, you should first check that the machine is properly connected to a water supply and that the water supply valve is turned on. You should also check that the machine's water filter is clean and not clogged. Additionally, make sure that the float switch is functioning properly and that it is not stuck in the "off" position. If these steps do not resolve the issue, you may need to consult the machine's manual or contact a professional for further assistance.
2/14/2023 8:15:39 AM •
Hoshizaki...
Answered
on Feb 14, 2023
HOSHIZAKI MODULAR FLAKER IS TRIPPING 1A FUSES WHEN TURN ON THE SWITCH.
Question edited for typo.
Question moved from Washing Machines Category.
Please don't type in all CAPS, it is considered SHOUTING and rude, plus harder to read.
You have a dead short to earth. Strip off all the panels and look for water where it shouldn't be and chaffed cables especially near holes in the casing. If you can't find anything, you need to check individual items, compressor, pump, and grinder with a multimeter. Or just call for service.
2/8/2023 4:06:01 AM •
Hoshizaki...
Answered
on Feb 08, 2023
Hoshizaki ice machine beep 3
in the freeze cycle too long. Most common is the water valve leaking through. Second thing to check is for a stuck float switch.
4/19/2022 11:35:44 PM •
Hoshizaki...
Answered
on Apr 19, 2022
All cycles work except harvest manitowac ice
Ice thickness probe on Manitowoc and float switch may be dirty or stuck if hoshi. Manitowoc sometime the thickness probe can get dirty and a film of algae and not sense ice properly but rare
1/21/2020 9:03:37 PM •
Hoshizaki...
Answered
on Jan 21, 2020
Why is my ice machine compressor over heating
usually from not enough refrigerant in the system. compressor overworking. excessive heat could also be from the compressor being bad such as bad valves. should be checked out by a service tech as this could involve removing freon to make repairs.
6/17/2017 11:26:16 PM •
Hoshizaki...
Answered
on Jun 17, 2017
I have a Hoshizaki KM900MRH
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
6/17/2017 11:19:57 PM •
Hoshizaki...
Answered
on Jun 17, 2017
Where is the reset for
most all machines by Hoshi, the reset button is on the control board. take your time and look at it as it is labeled but is very small.
6/17/2017 11:14:37 PM •
Hoshizaki...
Answered
on Jun 17, 2017
