20 Most Recent
Brother MFC 3220C All-In-One InkJet Printer Questions & Answers
What is 3220C compable with
likely this is because Windows doesnt come with the drivers built in for your model of printer.
go here http://www.opendrivers.com/modeldriver/Brother_Printers_MFC-3220C-driver-download.html
or Brothers own website for their drivers - the link below is the portal page for your model printer;
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/model_top/colormfc/mfc3220c_eu.html?reg=eu&c=eu_ot&lang=en&prod=mfc3220c_eu
Printer will not print
Not good this is your printer head.
Error 41 means there is a major problem with the printhead, usually
requires a print head replacement.
My advice is to take it to a
Brother service centre while if it is under warranty.
If it's out of warranty they are usually a throw away job, the heads cost as much as the printer.
Sorry I know what it feels like, just have a go and see what you can do, clean the heads and so on.
All the Best and good luck: Pineworks
My printer has an error #41 on the screen what
THE ERROR 41 INDICATES AN INCORRECT VOLTAGE COMMING FROM THE PRINTHEAD, THE PRINTHEAD WILL NEED TO BE REPLACED AND THE HEAD I.D. WILL NEED TO BE RESET, ALSO, BROTHER RECOMENDS THAT YOU CHANGE ALL OF THE INKS TO NEW INKS. THE RESETING OF THE HEAD I.D. CAN ONLY BE PREFORMED BY AN ATHORIZED BROTHER SERVICE CENTER. THIS REPAIR CAN NOT BE PREFORMED BY THE END USER. I HOPE THIS HELPS.
My fax machine is saying error 41
Hi there
Error Message
requires a print head replacement. My advice is to take it to a
Brother service centre while it is under warranty. If it's out of
warranty then it is cheaper to purchase a new, non Brother model. If you have been using non-Brother cartridges or refills, they can have too much water in them and it erodes the print head after a while. Usuall y just after warranty has expired!
Error 41 near empty black and near empty cyan.
first, the error 41 will eventually come back sooner if not later.
error 41 means that your printhead is failing.
the error that its giving you now is that your black and cyan cartridges are empty. there are 4 colors in your prnter.
Error 41 on Brother MFC
Dont bother checking anything. It needs a new print head and 4 new
cartridges to prime it with. Call Brother and raise hell! there have a
been a huge amount of these head failures! a new head costs around
$100.00 but if you press brother will replace it. Including catridges it should come to around 150$
