20 Most Recent
Samsung Digimax L70 Digital Camera Questions & Answers
My samsung L70 camera is
Looks like it's time for new battery. EBay is a great source for inexpensive new batteries,
Good Luck
I have dropped my camera and the zoom lense is
Yes, it can be fixed.
You just need to sent it to the store/any convenient electric store where you had purchased it for them to have a look at them and exactly what part is damaged.
Then, from there they will tell you whats wrong.
My samsung digimax L70 lcd
You could buy it from :-
http://cgi.ebay.com/LCD-Screen-Display-Parts-Samsung-Digimax-L70-L-70-/280389738500?pt=Digital_Camera_Accessories
Good Luck!!
Thanks!!
Samsung digimax L70, wont read any SD card, have
Is the card properly inserted, try to check recheck and double check. cameras some times, give the guidance as a computer. it might be the card you got is not original, or was a product of a fake company. By the way how is the forecus of the camera. If you install the card in a computer is there anything appearing, in most cases there are people who temper with the genuin labels and most systems nowadays they are computerised to differantiate between the original and the fake products.
Welcome BeDeche.
How do i hard resent my samsung Digimax L70 can
If you mean reset the camera by not using the "reset" function found in the menu, here's how...remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
How to stop the flash being so bright
Unless you have a top of the line adjustable flash you canNOT.
A flash unit is designed to give you a burst of light at the time your shutter opens so the camera has enough light to take a photo.
They are designed in such a way as to give enough light under nearly all conditions, but as with ANY fixed setting, it will sometimes be too bright and sometimes not enough.
I recommend you leave as is.
I have purchased a 8gb memory card for my samsung
if that happens try to reformat your sd card
all you need is a card reader and plug it in your pc find format and choose fat32*note only fat,fat16,fat32 format can be read by your camera so be careful when doing so.
Camera won't focus
Check whether you have a proper lighting in the rom, try to use the camera in outdor and check whether the autofocus is working..
Also check whether the camera setting is set right, if the camera is set to MACRO mode and if you focus distance object it wont get focuses..
Even if the setting is right and the camera is not focssing then you have take it to sevice center to service it..
Please leave me comment, if you need further assistance
Thanks for using Fixya
Please rate this solution
Rnj VinodKumar
How do I use the focus
be sure your lense and autofocus sensors are clean first thing.. then push the take picture button half way and it will autofocus. Pressing hte take picture button fully then will snap the picture.
