Frigidaire FFLE1011MW Electric Washer/Dryer Laundry Center - White Logo
A
Anonymous Posted on Jan 06, 2014
WASHER WON'T START
Three beeps when I push cycle start, but washer won't start. Checked breakers, pulled plug and re-inserted plug, still won't start.
  • Cheri Ellis
    Cheri Ellis Apr 18, 2015
    did you ever get an answer to your problem? i am having the same problem.
  • Official Brand Answer 2,267 Answers
  • Posted on Apr 22, 2015
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1290106
Points
2557
Thank you for your inquiry, friend!
I see that you are having trouble with your Frigidaire washer not starting. This sounds like a possible problem with your control panel or keypad. You may need to disassemble the washer in order to pinpoint the possible problem this is not a simple DIY job. I would recommend seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid future issues as well as possible multiple part purchases. I hope this information is helpful. -Matt
5 Related Answers
Anonymous
  • Posted on Nov 24, 2007
SOURCE: error code "loc" on GLTF2940ES0 washer
turn the selector knob so the machine comes on then press the "options" and "select" bottons at the same time for 3 seconds.
ohms
monk3ybidzness
  • 1879 Answers
  • Posted on Oct 31, 2008
SOURCE: LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Anonymous
  • Posted on Jan 22, 2009
SOURCE: frigidaire front load washer will not start
You need a new front controller board part # el1347360
dweatherby
  • 239 Answers
  • Posted on Apr 18, 2010
SOURCE: during any cycle washer will stop and beep and
i believe that code is water related not getting enough water maybe drain hose is too far down drain and unit is siphoning
Anonymous
  • Posted on Aug 20, 2011
SOURCE: When I turn on my Frigidaire Affinity washer, ERR
I have the same problem and i was curious if you have found a solution.
Thanks
I have a frigidaire gallery front load washer that won't start a regular wash cycle.When i select a regular cycle and pull up the start knob,the cycle light comes on and nothing happens.When i mov
Good Afternoon Leszek - Thank you for your question. Based on the symptoms you are describing it sounds like the unit has a faulty timer or a potential wiring failure. Try reprogramming the unit by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn on the unit. If issue persists, then at this point I strongly suggest reaching out to a professional that can accurately diagnose and repair the washer.
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
When you push start button nothing happens
2helpful
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
