20 Most Recent
Kenmore 3.8 cu. ft. HE3 Front Load Washer Questions & Answers
F13 and F11 codes pop up
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Washer fills up with water when not in use.
You have a faulty fill valve. located where the fill hose is attached. if it is a hot & cold fill then turn tap off one at a time to check which valve is faulty. Replace faulty valve.
Replaced bellow in kenmore washer still leaks
Is the plastic housing (Outer Tub) in good shape? If the old boot was ripped, It might be the spider is also broken. Can you move the inner tub by hand and see if it lifts upward? If so you might have to get a new one. I had the spider bracket in the rear of the inner tub break in 4 pieces and too expensive to weld. So I bought a new top loader.
