20 Most Recent Dodge 2003 Grand Caravan Sport Questions & Answers
2004 Dodge Caravan Sport. Why doesn't it change into Overdrive?
Question edited for clarity and remove 'double negatives'. Question moved to model category. A pro grade scan tool computer will give you all the answers to that problem and why the speedometer doesn't work. Even a standard scan tool with give you basic DTC codes. https://www.google.com/search?q=auto+electrician+near+me
Automatic Transmission no longer shifting into overdrive
Dodge Forum https://dodgeforum.com > ... > Dodge Caravan Apr 11, 2017 - Dodge Caravan - Automatic Transmission no longer shifting into overdrive - We have a 2000 Dodge Caravan (4-cyclinder) with an automatic transmission. 01 Grand Caravan...no Overdrive, what to do? - Dodge Forum Mar 3, 2006 WTF! no more overdrive! - DodgeForum.com Aug 2, 2018 5th Gen 08+ No more overdrive - DodgeForum.com Jun 20, 2022 More results from dodgeforum.com..
4/26/2023 6:40:55 PM • Dodge 2003 Grand... • Answered on Apr 26, 2023
Brake problem whats causing or what part
that leaves an internal booster issue or non return valve faulty to the vacuum line if you are sure the brake master cylinder is not bypassing internally at the cups cant be anything else no air in the lines and all calipers and brakes replaced should not have that prolem 26308586-4zkbh5ok4trbvla52ukeocnx-1-0.jpg
10/12/2016 12:09:14 AM • Dodge 2003 Grand... • Answered on Oct 12, 2016
2003 dodge grand caravan sport the abs light and brake warning light stays on cheked brake, fluids. what may be the problem
If the ABS light is on , there is a problem with the electronics of the ABS system . There is a DTC diagnostic trouble code stored in the EBCM - electronic brake control module . Your best bet is to take your vehicle to a Qualified repair shop an have it checked .
8/27/2016 8:03:22 AM • Dodge 2003 Grand... • Answered on Aug 27, 2016
Dodge grand caravan wont start. i disconnected the neg. on the battery. while i changed the control arm. and now it wont start. turning over but wont start. so can anyone help me?
use a scan tool to reset the ECM as the immobilizer has been activated by the removal of the battery circuit ( lead disconnected)
1/24/2016 1:11:26 AM • Dodge 2003 Grand... • Answered on Jan 24, 2016
Will a car remote start drain a battery?
Not unless a button is stuck on the remote.
12/30/2015 9:05:28 AM • Dodge 2003 Grand... • Answered on Dec 30, 2015
0answers
Brake light is on
Low brake fluid or park pedal slightly applied would be the most common problem. If brake fluid is low, have the brakes checked. It is not a good idea to add brake fluid unless there is a leak as the extra fluid will only spill out when the brakes are replaced.
6/14/2015 3:43:04 PM • Dodge 2003 Grand... • Answered on Jun 14, 2015
Where is the blower resistor located
behind the glovebox door. You have to remove the glovebox or at least tilt it out of the way, then just unscrew the resistor and unplug it and put the new one in.
1/28/2015 3:09:09 AM • Dodge 2003 Grand... • Answered on Jan 28, 2015
How do i by pass a pinhole leak in the steel tubing on the rear heater core ?
There are always 2 hose connections going to the heater in the vehicle.. One brings the water into the heater and other takes the water back out.. They are usually on the firewall in the engine compartment, and on the same side as where the heater will be inside the vehicle, under the dashboard.. Did you bypass both of them?
8/19/2014 4:21:56 AM • Dodge 2003 Grand... • Answered on Aug 19, 2014
My brake lights rear turn lights dont work on my Dodge charger 2008
Your brake system fuse has blown here.Or light wiring switch is not working.It could also be that the brake bulbs have burned out.
6/11/2023 6:44:26 PM • Dodge Computers... • Answered on Jun 11, 2023
1994 dodge spirit. Shifted cable
The shift cable on a 1994 Dodge Spirit connects the gear shift lever to the transmission, allowing the driver to shift gears. If the cable is damaged or worn out, it may need to be replaced. Here are the general steps to change the shift cable on a 1994 Dodge Spirit:
  1. Park the car on a level surface and set the parking brake.
  2. Locate the shift cable where it connects to the transmission. It will be on the driver's side of the vehicle, near the front of the transmission.
  3. Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the transmission.
  4. Trace the cable up to the gear shift lever inside the vehicle.
  5. Remove any trim pieces or panels that are blocking access to the cable connection at the gear shift lever.
  6. Use a pair of pliers to remove the cable retaining clip or nut that secures the cable to the gear shift lever.
  7. Remove the old shift cable from the vehicle.
  8. Install the new shift cable by first attaching it to the gear shift lever and then connecting it to the transmission.
  9. Secure the cable to the gear shift lever and transmission using the retaining clip or nut that you removed earlier.
  10. Test the new shift cable by shifting through all of the gears to ensure that it is functioning properly.
  11. Replace any trim pieces or panels that you removed earlier.
2/19/2023 6:42:15 PM • Dodge Computers... • Answered on Feb 19, 2023
Serpintine belt on 2000 dodge caravan needs attaching
I take it you mean installed. The belt sequence for the pulleys should be on the cross member under the hood over the radiator or somewhere in that vicinity. Follow that pattern and you will have to put a ratchet in the front og the belt tensioner to turn it down far enough to get the belt the rest of the way on. Go to youtube and do a search on how to do it. Someone will have a video showing how to do it.
8/17/2019 1:11:51 AM • Dodge Computers... • Answered on Aug 17, 2019
Why won't my car start after charging battery on 2015 dodge dart
5/20/2018 9:45:45 PM • Dodge Computers... • Answered on May 20, 2018
0answers
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/25/2024 6:13:32 PM • Computers &... • Answered 9 hours ago
Dodge 2003 Grand Caravan Sport Logo
20 questions posted
Top Dodge Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Dodge Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dodge Computers & Internet
Most Popular Question
brake problem whats causing or part
  • Computers & Internet
