20 Most Recent Whirlpool GHW9400 Front Load Washer Questions & Answers
2answers
Water stays in Gasket on Whirlpool GHW9400 Front Loader
The tiny holes at the bottom of the door seal are blockedcarefull push a small screwdriver through yhem to clear them out
1/11/2018 9:33:03 AM • Whirlpool... • Answered on Jan 11, 2018
One minute left
be sure water is draining out before spin starts if necessary remove bottom panel and clean pump out and ck hoses to pump be sure there are no excess suds ..wash only full loads small loads or loads with 1 heavy item will cause washer to sense off balance and try to balance load this will extend cycle time
12/2/2017 7:46:29 AM • Whirlpool... • Answered on Dec 02, 2017
I just viewed a bunch of complaints about chlorine
chlorine bleach is a highly corrosive addition to laundry that is not necessary... try Borax and Hot water. If the clothes sat in the Bleach for the entire wash cycle it would damage them and shorten the life of the clothing fibers considerably...
4/25/2017 7:09:10 PM • Whirlpool... • Answered on Apr 25, 2017
Washing machine wont go from wash to the spin etc automatically
Do not fool with this you will void the warranty, you have a defective machine, contact the manufacturer.
4/17/2017 9:08:38 PM • Whirlpool... • Answered on Apr 17, 2017
Why doesn't it run or spin with a heavy load sometimes?
After several years of work, belt loses elasticity and should be replaced. Dado
11/30/2015 10:48:06 PM • Whirlpool... • Answered on Nov 30, 2015
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
12/4/2014 8:07:49 AM • Whirlpool... • Answered on Dec 04, 2014
0answers
Tub shakes like crazy , have to stop machine , please help
Firs thing to check is that the machine is level from front to back and from side to side. This can be adjusted with the screw adjustable feet on the bottom. Next is to not over load the machine and make sure the load you have in there is evenly balanced/distributed when it starts into the spin cycle.
6/2/2014 12:16:29 AM • Whirlpool... • Answered on Jun 02, 2014
When spinning off balance support messed , plastic gasket is broken
You can check this link for parts
5/31/2014 8:45:26 PM • Whirlpool... • Answered on May 31, 2014
My whirlpool front load washing machine accept hot
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
4/11/2014 12:58:54 AM • Whirlpool... • Answered on Apr 11, 2014
0answers
2answers
I keeg getting the dreaded F11 anf DL code!
The following list of codes indicates an electronics communication problem with the washer:
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service.
Take care
2/19/2014 12:37:42 AM • Whirlpool... • Answered on Feb 19, 2014
0answers
0answers
What is code "17" when running wash cycle
Are you sure it is a "17"?
2/18/2013 3:12:40 AM • Whirlpool... • Answered on Feb 18, 2013
Whirlpool GHW9400 Front Load Washer Logo
141 questions posted
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
View Most Popular
  • Whirlpool Washing Machines
Most Popular Question
control lock light control panel not
  • Washing Machines
