20 Most Recent Miele 24 in. G665 Built-in Dishwasher Questions & Answers
How do i unclog dishwasher
There is probably a removable, plastic 'screen' in the bottom, cleaning area. It should either 'snap out', or have a squeezable clip, to remove it.... Beneath it MAY be your clog. Otherwise, it may be a more serious problem.....
2/12/2015 10:47:37 AM • Miele 24 in.... • Answered on Feb 12, 2015
How to fix the tablet release compartment. Doesnt release every wash only sometimes
Probably solenoide defect, remove the power first and then the cover, then you can ohm it out to see if it is shorted, replace if necessary
2/3/2015 12:20:13 AM • Miele 24 in.... • Answered on Feb 03, 2015
Does the Miele G665 dishwashers have a heat element as no heat is coming from my dishwasher
If it like other Mieles, it has an element to heat water if required to reach cleaning temperature, but does not have a drying element. Even then, it should give off some heat in the drying cycle and be hot after finishing.
11/25/2014 5:30:50 PM • Miele 24 in.... • Answered on Nov 25, 2014
Miele dishwasher leaks when door opened and end of wash
Do like the others said. This is what I call the Miele Problem! This happens every year or two. Take off the outside front panel to access the hose that runs from the bottom of the fan down to the dispenser, and lets the water drain out through it to the interior. Clean out that hose as well as you can. Replace. This is a stupid problem that Miele should have a permanent fix for. Grrrr. In fact I just did this with mine today. The hose cleans out quickly, the problem is getting the front back on. 4 hands make it easier. It slips on when you start close to vertical, then slip in in and down. For putting the screws back in, you might have to use a micro screwdriver to re-align the little clips on the door panel. (You will see what I mean when you do it!) This costs a service call ($100, give or take) to call for service. It can be done at home with no added parts. I think it applies to all Miele dishwashers, and I have now done it several times. As I said before, this is a design fault and should not be necessary! If you have a helper to help contain the mess, you can spray water into the fan area (best is backward through the hose, but try all directions) and catch the runoff. We have done this and it catches a lot of gunk.muck and slop. Doggone design sucks on an otherwise nice machine!!
7/27/2014 9:29:21 PM • Miele 24 in.... • Answered on Jul 27, 2014
2answers
Miele g665 leaking water from turbothermic vent
I had this happen too. There is a rubber venting tube which runs from the vent on the door to the rinse/powder release pods. This clogs up and the water then comes out when the door opens. If you take off the front panel of the machine (screws are on the sides) it is easy to take off and clean out by running hot water through it, also clean out the line through the release pods .. problem should be solved.
7/27/2014 9:25:52 PM • Miele 24 in.... • Answered on Jul 27, 2014
Tablet does not dispence
this is electrically activated and spring controlled and almost always the mechanism just needs cleaning particularly if you use a powder or tablet type detergent. you can try leaving the compartment open and running a few cycles without any detergent to help clean it up,otherwise you will have to take that piece apart and clean it up by hand. also check the electrical connection to this part. A bit of moisture to it will cause corrosion also causing it not to work.
6/29/2014 4:00:10 PM • Miele 24 in.... • Answered on Jun 29, 2014
0answers
0answers
Our miele 665 has the
Hello & Welcome to FixYa
Good to know that you want to keep this dishwasher as I believe it can be fixed. After reading your question the problem seems to be with the Timer that is bad and needs replacement. Every other part of the unit seems to be working properly, so you can check the timer motor and replace if bad. Please get back to me if you have any other questions.
Kevin
11/3/2013 1:54:33 PM • Miele 24 in.... • Answered on Nov 03, 2013
0answers
Unblock drain
Be the first to answer 9/1/2013 11:23:57 PM • Miele 24 in.... • Posted on Sep 01, 2013Be the first to answer
Hi my miele dishwasher g665 no hot water or drying
new heating element
8/20/2013 5:52:32 AM • Miele 24 in.... • Answered on Aug 20, 2013
Miele 24 in. G665 Built-in Dishwasher Logo
73 questions posted
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
Miele Dishwashers
  • Miele Dishwashers
Most Popular Question
miele g665 leaking water from
  • Dishwashers
