SOURCE: need the manual for Aeg oko lavamat 74630
Dear Biyo,
Please download the manual from here. (simply press left click)
http://www.manualshark.org/manualshark/files/5/pdf_10516.pdf
I have sent you an email as well.
Regards,
EngineerGR
SOURCE: AEG Lavamat Turbo 12830 - error code E20
Hi
E20 means there is a bolckage in there
remove filter and clear any debris in there and check impeller is turning ok.
regards
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
SOURCE: oko lavamat 74640 update showing error E20 what
its a draining error, check sump, pump and drain hose for blockage failing that it needs a new pump.
SOURCE: AEG OKO LAVAMAT 72630 is showing E20. what does
Error code E-20 means drain problem.
It means that the machine is not draining water correctly. Check the drain hose, to see if it is kinked or folded over. It could also be that the drain pump or drain hose are clogged. Drain the pump (check behind the little panel at the bottom right of the machine), first draining via the small emergency drain hose if you want to avoid a large puddle.
Also get the fluff filter removed and checked.If the filter is clogged then it will not let the water to get drained.
The fluff filter is behind the little trapdoor below and to the right of the drum on the front of the machine. Open the door, unscrew the filter, and pull it out. It will be covered in smelly slimy multi-coloured fluff, which you need to remove. When you remove the filter, there is a good chance that a fair bit of water will come out at the same time, so, if you can place a very low bowl or similar below the filter before you unscrew it it will save you from having to mop the floor.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this
solution and show your appreciation.
