HP Officejet Pro L7590 All-in-One InkJet Printer Logo
Posted on Mar 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hp officejet pro L7590 - automatic document feeder will not pick up - how do I fix this problem?
Tejodhar Atreya Uppaluru
Level 2:
Guru:
  • HP Expert 314 Answers
  • Posted on Mar 03, 2010
HP Expert
Level 2:
Guru:
Answers
314
Questions
0
Helped
120047
Points
868
Hi
Check the following
--Check the paper in the ADF (automatic document feeder)
--Make sure the ADF pick assembly is in good working condition
--Remove the document feeder and open the ADF cover.
--While lifting the blue-green lever, carefully rotate the pick assembly toward the open ADF cover until it stops.
--Make sure the bottom roller is held firmly in place by the two-catch, which is located to the left and the right of the roller.
--Clean the rollers and separator pad
303 Electronics
Level 3:
  • HP Master 370 Answers
  • Posted on Jan 30, 2019
303 Electronics
HP Master
Level 3:
Answers
370
Questions
0
Helped
404692
Points
2643
You will need to clean the ruuber rollers. Check out this video. It has a different model, but same kind of steps apply to this model:
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
1helpful
How do you fix the feeder
Plz follow this link :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01110425
1helpful
I can't get my OfficeJet Pro L7590 to feed documents through the Automatic Document Feeder.
Here is a link to HP's support docs on the subject. (and here) and here and here.
If you have access to compressed air you can GENTLY blow through the machine to remove dust that's built up.
Otherwise, here is the home page for support for your printer. Perhaps there's some info in the hp forums that may help....
Best of luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
1helpful
Automatic document feeder not working
Open the adf and rotate the pick assembly till you hear a click and then take a coin and run it up and down against the separator pad and then see if the adf picks the paper or not.If this does not work try this *# 329 and scroll thru and select adf pick test if that fails its time for you to get the printer replaced or get an upgraded printer
3helpful
2answers
Paper get jammed in the automatic feeder on top of my printer
3 possibilities.
1 If you use this macine to copy labels, there may well be a small piece of a label stuck in the paper path on the crumpled side. Or a small bit of paper.
2, the paper pickup on the crumpled side is 'polished', and no longer feeding the paper at the same time as the uncrumpled side. They can be cleaned with rubbing alcohol. Though that is a temporary fix and the paper pickups should be replaced if cleaning fixes the issue.
3 The fuser film has a tear in it on the crumpled side you need to rule out 1 & 2 before going to three again replaceable but a bit more difficult
7helpful
Feeder tray does not feed during fax
Hp help
Automatic Document Feed (ADF) does not pick up paper. Follow each step, problem seems to be in pick assembly. Prcess took less than 5 minutes with a successful outcome.
1helpful
2answers
Jam in the document feeder
get rid of that hp piece o crust. demand your money back.
k24674
Grand Canyon Tech
Grand Canyon Tech
