Refrigerators Logo
Posted on Feb 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My uline keeps running and soda in cans freeze. Thermostat setting is at lowest but I also tried midway. Model ULN-CO75FWH-00
exploreris
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 176 Answers
  • Posted on Feb 21, 2010
exploreris
Expert
Level 2:
Cheetah:
Answers
176
Questions
0
Helped
52700
Points
482
Your thermostat is bloked or didn't see the reeal temperature, it must be replaced whit similar new one.
1helpful
U-Line ULN-15WCSS-00 Built In Wine Storage Refrigerator. How to remove and replace wine racks in ULN-15WCSS-00 please.
Question edited for clarity, maker.
Question moved from Watches to U-Line Wine Fridge.
They are usually an expanding plug. You push it to the hole and press the central pin. If you can grip it with pliers, you can pull it out. The other way is to use a nail punch and push the pin all the way through, pull out the support and retrieve the pin from the insulated cavity.
https://www.amazon.ca/s?k=U-Line+wine+fridge+shelf+support&i=tools&crid=6P110ETE4YHD&sprefix=u-line+wine+fridge+shelf+support%2Ctools%2C69&ref=nb_sb_noss
https://www.google.com/search?q=u-line+wine+fridge+shelf+supports
1helpful
Even on lowest setting, drinks too cold, freezing at back, ice.
Thermostat needs replacing. Can`t find one online but I would guess a standard Danfoss would do it.
1helpful
1helpful
3answers
Fridge Freezes Everything
there is a motor with a flapper that opens and closes to keep your temp correct in the refrigerator side most likely the motor is bad and stuck open so your air from the freezer has constant flow to the refr side. the flapper is in the back of the refr behind a cover where the air flows in.
My side by side refrig. keeps freezing everything. It is turned lowest setting. Model GLRS2677AW6
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
2helpful
2answers
Ice maker will not harvest
As crazy as this sounds, turn the temp control a little warmer (counter clockwise). On this model, this control needs to switch to harvest the ice. A warmer setting should fix this issue.
Dean
You can also go to:
www.u-lineservice.com
2helpful
Jenn Aire refrigerator keeps freezing food.
Your thermostat is faulty, pure and simple.
If the thermostat fails to do it's job, your compressor continues to run thus freezing your produce.
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
