Re: Keyless remotes won't work after battery change.
Remote has to be reprogramed. Look in owners for proceedure. If you don't have a manual call the dealer. May have to take vehicle to them to reprogram it with a scantool
2000 Avalon keyless remotes stopped working: solution Both keyless remotes for my 2000 Avalon stopped working. The batteries were good (I checked them with a volt-ohm meter). The Toyota dealer determined that the remote used most was defective and it tried to initialize the receiver in the car. This caused the second remote also not to work. The dealer reset the receiver (reinitialized it after first unplugging it), replaced the defective remote with a new one, and reprogrammed both remotes. Total cost: $225 labor, 164 for new remote. Later, another remote went bad. I just stopped using it.
If your keyless entry remote has never worked it either needs to be programmed to the vehicle or it is the incorrect remote part number for they vehicle. First step is to call your local dealership, ask for service, then verify your vehicle came equipped with the keyless entry option and verify the key fob part number. When calling the dealer have your vin# handy, they will need that. Once you have verified your vehicle has keyless entry option and you have the correct keyless entry remote part number then find a locksmith to program the remote to your vehicle. We suggest a locksmith because they are usually more affordable than the dealer and they come to you.
If your keyless entry remote has worked before and it just stopped working, here are a few tips to try to get it working again:
1) Change the battery
Batteries don't last forever, you'll be surprised how often it's just a dead battery! Search our YouTube channel on how to change a key fob battery for your specific year, make, and model!
2) Wipe the board
The board inside your remote can get a lot more filthy than you think! When the board is dirty it can prohibit the contact to the circuit board when you push down on the button. Simply wiping the circuit board off can make your key fob like new again!
3) Get it checked
Go to your local hardware store like AutoZone or Oreilly's. They usually have a RF frequency tester. This little gadget will let you know if your key fob is sending a signal. If it is, you may need to reprogram your key fob to your vehicle
4) The old car battery reset trick
I know this sounds absurd, but it works sometimes and is worth trying. If you exhausted all of the options above, disconnect both terminals on your car battery for 10 minutes. Then reconnect them and try your key fob. This has worked for many people and I have no idea why. If you do, please comment below to explain.
5) New fob!
It might be time for a new key fob! No need to dread over the expensive costs of a new key fob, at Keyless Entry Remote Fob Inc., you can get a refurbished one for a very affordable price! You won't even be able to tell the difference. Just search your vehicle make, model, and year to purchase a key fob or give us a call at 402-671-5100.
you dont need to worry,use the key as normal (put in lock to open door)it will still start the car,just split the remote with your hands and the battery is inside it,you can get one at the newsagent,or supermarket easy job
You can take it back to the dealer, and have them change the battery, or go to Autozone, buy the battery and do it yourself. They can show you how to do it. And which battery it takes. It's not hard to do. Good luck.
Regarding the remote transmitter issue: Take the remote transmitter to your Toyota dealer. Ask them to test your transmitter with their hand-held RF detector. All Toyota dealers are required to have one of these devices. The RF detector will test the remote to see if it is indeed transmitting the proper RF out of the transmitter, and the strength of the RF signal. If there is no signal, the remote has failed (unfortunatly common), and the remote will need to be replaced and reprogrammed to the vehicle. I do this quite regularly, and rarely do I tell customers taht they need to spend 800 dollars for such a simple diagnosis/fix. The keyless system is very reliable. I rarely change the ECU for the keyless, unless somebody somehow gets the ECU wet, then it def needs replaced. Hope this helps.
