Televison & Video Logo
Ally Tucker Posted on Oct 14, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get the dvd out of the GE6823 as I put it in the wrong way I'm guessing? Cant find any way to eject it
Herb Box
Level 2:
Filmmaker:
Uploaded 5 video answers.
  • Expert 117 Answers
  • Posted on Oct 14, 2019
Herb Box
Expert
Level 2:
Filmmaker:
Answers
117
Questions
0
Helped
59513
Points
361
Try removing the back panel. The DVD itself may have its own cover. Try removing that to access to stuck DVD.Remember to unplug the TV from the mains before attempting to remove the panel.
2 Related Answers
Anonymous
  • Posted on May 20, 2009
SOURCE: DVD in the wrong way; won't eject
Apart from taking it apart! or forcing the disc tray out "DON'T" !!! try switching off at mains holding eject button continuosly pushed in and put mains back on, sometimes this causes a full "re-boot sequence" which from experiance and several attempts, does throw me the tray open!
snakehead
Henry Thomas
  • 1074 Answers
  • Posted on Feb 28, 2010
SOURCE: DVD Player on my combo Sharp ejects the DVD
your cet is saying to you that it can only play dvd of a certain region.you need to purchase a dvd player that can play all region dvds. buy a samsung, panasonic or sony all region dvd player they will be able to play all your dvds.good luck.
I have a 2006 Jeep Commander and I cant locate the CD eject button referred to in the manual (EJT CD). Where the hell is it?
my guess, no photos from you (our horror)
its NOT STOCK.
or the glove manual , is wrong, wrong year, or wrong page
the stock, cars have up to 3 audio system stock,
and the put all 3 in the book.
if not stock or wrong head there (was changed out)
then the real radio probably is in H3LL.
Why does my Dvd player in Flatscreen TV continue to try to eject disc when it has already been taken out?
My first guess is that something is jammed inside and is triggering the eject mode.
Have you tried inserting and playing a disk?
CD stuck in DVD player in tv
I'm sorry that the disc tray is not ejecting. Please check whether you're able to locate a small hole under the tray opening area. If one available, please insert a pin and it will eject manually now..
1helpful
Trying to create back first disc 100% burnt but cant eject to put in another
Hi
Go to My computer, right click the cd/dvd writer, and choose 'Eject',
if it wasn't get out, so you need to use tall needle softly inject it in the hole near the cd/dvd writer light and press it inside softly, then the cd/dvd writer will be ejected.
Take care, use the needle carefully.
Please tell us your results
Good Luck
When I put a dvd in the dvd player, it doesn't play, the dvd player ejects the dvd.
Buy youself agood dvd lenz cleaner. When it gets dirty it cant read the cd so it ejects it
Good afternoon hp: I have an hp model: s5120y. I've not removed the system disk until today. I've had this computer about 7 months. In attempting to insert a disk to view a movie there is nothing to hold...
how to use a vertical DVD drive.
so read the manual yet, page 23 (says only UK?) not sure why UK.
http://h10032.www1.hp.com/ctg/Manual/c01863412
omg the daft HP writer fails to say there.
my guess,,
it snaps in place.? i cant see close enough to tell.
Or ? to hold it with finger, next to hub of disk
push Eject (retract now) button and it sucks it in and pray
not jam.
it would have to be a special dvd driver there to work right.
in that vertical position
in the parts surfer for this PC no DVD drives listed, so i cant find the exact model. amazing fact and bad.
the only post at HP forum is the word INANE desigh
says put the PC layed flat to put the disk in.
wow.!\
as seen here
https://h30434.www3.hp.com/t5/Desktops-Archive-Read-Only/I-have-hp-pavilion-slimline-with-vertical-dvd-drive-Can-I/td-p/727097
or the bloke
that sold this use the wrong drive. and the hp parts list fails to show it, (wow2)
this page proves such drives (special ) work right.
https://superuser.com/questions/923546/how-can-an-optical-drive-function-when-mounted-vertically
eject the tray look here.
see the 3 spring loaded tabs here
yes good, no bad.
this is snap in drive, version
1helpful
I took my dvd apart to get some coins out & now it's unresponsive
I am guessing you had a disc in the drive when you took it apart (or maybe the coins had something to do with it).
What you need to do is disassemble the Bluray drive again. With the top cover off of the Bluray drive, power on the PS3, then hit the eject button. The plastic guides should snap into the right position and then you can reassemble and it will work again.
I can't access the DVD features on my Westinghouse vk-40f580d, I put the dvd in and go to the DVD menu, but wont let me use any dvd controlls, it wont on the remote and tv buttons, AND I cant eject, please...
to eject the disc, turn off your TV and hold the eject button then power TV back on. Regarding the DVD feature not working, you may need to change the main board. If your TV is still in warranty, call 1-800-701-0680 for an in home service.
VHS tape plays for a few seconds and automatically ejects
My guess would be dirt on the rollers inside the VCR. They sesnse a jam and ejct. Try a VCR cleaner (with cleaning fluid) and see if that helps.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
