My fridge keeps tripping the earth leakage breaker. It appears to have burnt out the defrost heater but I cant find a way to access it
Take it off the gfci.
Test the fridge for defective wiring, use a 120v test light from fridge metal to a known good ground source. A slight tingling when defective fridge grounding connection to a strong electric shock would be felt from fridge metal chases to a known ground source when severely defective.
The wiring terminals in the vecinity of the evaporator are exposed to moisture and frost with a path to ground thru metal refrigerant circuit tubing.
HEY!!!!! If your breaker is tripping it means you have a short circuit - a serious safety issue.
Unless you are a qualified electrical tech, for safety reasons refer this one to a pro.
SOURCE: Fisher & Paykel active smart fridge keeps
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
SOURCE: fisher paykel e522bre active smart refrigerator
you need to have the defrost element replaced !!
SOURCE: ice building up back of freezer and fridge not
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
