20 Most Recent Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Questions & Answers
2answers
The fridge isn't as cold as it should be, all
Seems to be a common problem. Same problem with our fridge. (10 minutes to fix = apprx. $200) One of the wires for the fan breaks. I suspect F&P know about this and I suspect are making a lot of money in repairs
2/11/2023 9:34:24 AM • Fisher and... • Answered on Feb 11, 2023
19answers
Beeping constantly in middle of night
My fridge (E440T but I believe the E522B is similar) also had a broken fan wire. I pulled off the panel and re-soldered the wire. I also created a document for others to follow if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
11/28/2022 4:22:18 AM • Fisher and... • Answered on Nov 28, 2022
10answers
Leaking Fisher and Paykel Fridge
i have a fisher and paykel 450L fridge and its been pissing water out underneath the vege crisper since day one, i was told by f&p whilst it was under warranty that it was because of the humidity and constant opening and closing, i finely had enough of cleaning up fridge pee! you shouldnt have to do this for a 2 year old fridge, god sakes the 20 year old beer fridge doesnt leak. rang f&p and booked a service call $121 fast bucks, had to be available from 12miday untill 5pm bloke showed up at 4.45. inside the fridge he took the back panel off and then got out a part from his bag a long black thing with wires and attached it to the?whatever, but get this! it wasnt a replacement part, this fridge never had this part, so what? did they forget to put it in? and ive have to put up with fridge pee for 2 years?? and why do i have to pay the $121? he told me i wouldnt have to pay for the part? whippee? i already paid for it when i bought the "faulty" fridge. ill be getting to the bottom of this, does f&p know there is a fault? and they dont bother to fess up? lucky they dont make cars!!!! took about 10min and so far no more fridge pee!!
6/26/2021 5:56:16 AM • Fisher and... • Answered on Jun 26, 2021
2answers
What is fault code 2
The resistance of the Evaporator Sensor is outside of the normal range (> 45k ohms).
Primary Action
- Check sensor connection at controller.
Secondary Action
- Replace sensor.
5/8/2021 10:39:36 PM • Fisher and... • Answered on May 08, 2021
I have a problem with my old Fisher & Paykel
the pump has either something jammed in it so remove it and check,if good check the pump copper windings for any uneven coloring if darker in one area replace pump
12/21/2018 8:04:16 AM • Fisher and... • Answered on Dec 21, 2018
Fisher and Paykel N500B fridge not cooling but lights on
if not humming at all then i would say a new thermostat should fix the problem
12/21/2018 8:00:25 AM • Fisher and... • Answered on Dec 21, 2018
My fridge keeps continuously beeping - for no
will need someone with the correct diagnostic equipment to tell you whats wrong
12/21/2018 7:44:35 AM • Fisher and... • Answered on Dec 21, 2018
0answers
F&P E442b leaking from drain. Am i missing a evap tray????
Yes there should be a pan right next to compressor so heat from motor would cause it to evaporate.
You can just put a pan next to motor and strap it up
2/21/2018 5:18:47 PM • Fisher and... • Answered on Feb 21, 2018
Fisher paykel e224b fridge not cooling. everything working fine but fridge was originally pulled apart before i looked at it, need to know which thermistor is which (black and white ones in the freeze
Kitchen Laundry Appliances Fisher Paykel US Are you sure that is the part number. I went to the above link and could find nothing with a part number of E224B. Please look on your unit and verify there is no other numbers. If you find additional information please post it and we can attempt to help. Semper Fi, Z
2/1/2018 6:31:06 PM • Fisher and... • Answered on Feb 01, 2018
0answers
Alarm
Be the first to answer 1/19/2018 12:24:03 AM • Fisher and... • Posted on Jan 19, 2018Be the first to answer
I have a Fisher & Paykel E522B fridge that has
Check fans in freezer and near compressor. Is compressor running continuously or clicking on and off? If fans are running and compressor is running continuously, your problem is most likely within sealed system. That would require a technician and may not be cost effective to repair.
9/24/2017 4:31:28 AM • Fisher and... • Answered on Sep 24, 2017
0answers
Hi there, I have
Be the first to answer 5/31/2017 12:57:03 AM • Fisher and... • Posted on May 31, 2017Be the first to answer
Fisher & Paykel E521T Fridge Ice Build up behind Freezer compartment. I have had my fridge for about 7 years and ever since I bought this fridge I have to defrost it every 6-8 months because wate
Have they cleaned the drain tube that runs down the back of the fridge? If not and the tube is clogged water will back up and give you the problem that you are having. The only other thing that I can think of, is that the defrost cycle may not be set to a minimum amount of time to where this can be increased to allow the freezer not to let the ice build up.
4/19/2017 3:09:26 AM • Fisher and... • Answered on Apr 19, 2017
Noisy F&P fridge freezer
Most of f&p make this noise its most annoying, but could also be ice buildup on the fan blades, creaking and cracking is normal as the pipes expand and contract is these thin foamwall fridges, not nice fridges, insulation has been compromised to lower cost, they work twice as hard at keeping cool
12/15/2016 12:14:29 PM • Fisher and... • Answered on Dec 15, 2016
Why my freezer is snowing in cooler section
excess ice could be due to the door not sealing correctly, so ice would appear inside around the door area where the door seal does not seal correctly, OR the defrost heater may be faulty.
11/21/2016 11:43:40 AM • Fisher and... • Answered on Nov 21, 2016
Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
469 questions posted
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Refrigerators
Most Popular Question
beeping constantly in middle night
  • Refrigerators
