Hi Arthur, indicate the brand and model of the TV you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Arthur, indica marca y modelo del TV que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Find the TV code for
your TV in the list from the Platinum Remote Control User's Guide (See
References). For example, if you have a Kenwood TV, the three possible codes to
try are 506, 573 and 712.
Press the "TV"
button on the remote. Hold down the button until the "Sat,"
"VCR" and "Aux" buttons light up. Release the
"TV" button and it will be flashing.
Enter the first code
using the keypad. If you want the remote to control all functions on the TV,
enter the code and press the # key. The "TV" button will flash three
times.
Press the power button
to turn off the TV and turn it back on again. If the code was correct, the TV
will turn off and on. If the TV doesn't power down or back on, follow Step 6.
Try the next code from
the list. Follow Steps 2 through 4 using each code until one turns off the TV.
2. Programming Without Codes
Press the "TV"
Press and release the
"Power" button on the remote.
Press the arrow up key
and stop. If the TV doesn't turn off, press the arrow up key again. Continue
pressing the arrow up key until the TV turns off. Do not go fast when moving
through the codes or you could miss the correct code. Press the arrow key and
wait at least 20 seconds to see if the code works before pressing the arrow key
again.
Press
the # key on the remote when the TV turns off to lock in the code.
