My daughter pushed the menu button on the side of the TV more than 5 sec apparently and the TV went into a setup menu for first-time use. But without a remote, I can not set it up and get out back to the TV screen. The side buttons don't operate the menu. Is there a way to skip this setup when starting the TV or is it in another way possible to get past this setup? Appreciate any help, Thanks
Hi Phil Philips, try disconnecting the TV from the outlet, wait 30 minutes, reconnect it and see if it is corrected
If not, get another Philips remote control, usually all are compatible, remove it from the setup menu and then turn it off from the TV, until you get a new remote control
Hola Phil Philips, prueba desconectar el televisor del toma corriente, esperar 30 minutos, reconectarlo y ver si se corrige
Si no, consiguete otro control remoto Philips, por lo general todos son compatibles, sacalo del menu de configuracion y luego apagalo desde el televisor, hasta que consigas un control remoto nuevo
https://www.manualslib.com/products/Philips-32pfl7762d-12-385396.html
Testimonial: "Thanks for your answer. Unfortunately only the part of the new remote was helpful."
SOURCE: no picture
I purchased four 2200uf @ 25v capacitor’s for $8 at that same repair shop. I upgraded to 25v because these will run cooler. The tv came with 10v Samxon caps that seem to be problematic in all the units they were used in. Do not buy Samxon if you do this yourself.... I opened the set by taking off the plastic back panel and then by removing the second metal panel. There are three boards and a hard drive. The board on the far left just above where the plug goes in is the power supply board. There are five data cables and one red power cable attached to it that can be removed simply by unplugging them. The board is fastened to the unit with five small screws, one on each corner and one in the middle of the right side. If you look for three green capacitors grouped together around the middle of the board and slightly off to the right, you will probably see one that is bulging out at the top. This is most likely "C235", the main problem. The other three caps that need replacing are C202, C201 and C219. C219 is closer to the top part of the board.....
The process to replace is simple, believe it or not, and it could save you hundreds of dollars. 1, Go to RadioShack and buy a cheap soldering iron and a small roll of solder. 2, Buy four, 2200uf @ 25v capacitors, online or at an electronics store. 3, Plug the soldering iron in and let it heat up. 4, Locate C235 on the back side of the board and mark the negative terminal with a felt tip marker (you want to make sure that you put the negative terminal on the capacitor through the right hole, otherwise you will pop the cap. The negative terminal is clearly marker on all the capacitors). 5, With needle nose pliers, grip the cap and pull down while heating up the terminals. The cap will eventually come out. 6, Put the new cap in (you may need to heat the solder that is left on the board to clear the hole so it can push through). 6, When both terminals are through, bend them slightly so it stays in place. Take the solder and stretch out a few inches off the roll and while holding it in one hand, lightly touch the base of the terminal where it comes through the board, with the soldering iron and the solder at the same time. --- Try not to use too much solder.. you only need a tiny drop. This will solder the cap in place. 7, cut off the terminals close to the board with some snips and repeat this on the other three. 8, put the board back in, plug in the cables. Test the TV before putting the back panels on. It should work fine if all went well..... If you hear a pop than you reversed the terminals on a capacitor and that one will need to be redone correctly.... This might sound lengthy and potentially difficult but its worth a try. Otherwise you can pay someone to replace the entire board for BIG BUCKS with the same junk caps on it and have the same problem in a year or so. LG doesn’t want to take responsibility for this and I'm sure that it has cost a lot of people a lot of money for about $8 in parts........... This worked for me and it can work for anybody with the same problem.. Good Luck!
SOURCE: push on button dvr says set 2
Press ENTER and number 2 together on the remote control for at least two seconds to restore control.
SOURCE: remote control code
The remote control for your DVR has the capability to control 2
additional DVRs in addition to the one that you currently have. In
order for the remote control to work with your DVR, you will need to
make certain both of them are talking on the same frequency. If you
press the remote control and the front of your unit says DR2, that
means that you need to have your remote on DR2 as well so that it can
operate the DVR. To set your remote to DR2, you will need to make sure
the unit is off then you will need to press and hold down the SETUP
button and while you are holding this button down, press the number 2
button. Your remote is now set to DR2.
Good luck...
SOURCE: TV won't turn on
The set is in protective shutdown because a problem was detected. The 5 blink code indicates that the problem circuit. In this case it is the blanking circuit. Were there any indications of problems prior to the storm? If not, I'll need to lok up this one for the specifics. Do you intend to repair this yourself?
Let me know and I'll provide the details.
Thanks,
Dan
