20 Most Recent Philips 42PF9631D 42 in. Plasma Television Questions & Answers
32answers
Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
Here is a photo of the board where I have removed the two from my TV. You can see the two open holes.
11/6/2021 5:44:24 PM • Philips... • Answered on Nov 06, 2021
Flickering contrast
Could be a bad tcon or main board, below is the link for the manual if that helps Philips 42 50 63PF9631D 37 Manual
1/27/2018 1:33:24 PM • Philips... • Answered on Jan 27, 2018
0answers
TV SCREEN WHILE WATCHING WILL BLINK AND BLANK INTO BLACK SCREEN
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
5/12/2017 1:25:25 PM • Philips... • Answered on May 12, 2017
2answers
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
4/6/2017 10:46:59 AM • Philips... • Answered on Apr 06, 2017
Philips 42pf9631d/3 capacitors, 2 are 3300uf need replaced but there are other capacitors,diodes,zener diode and maybe a resistor, I need to know the values of those. Thanks
Service manual here... http://elektrotanya.com/philips_42pf9631d-10_chassis_fj3.0e-la_sch.pdf/download.html
1/9/2017 2:24:26 PM • Philips... • Answered on Jan 09, 2017
2answers
Philips flat screen 42
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
6/11/2015 4:58:09 AM • Philips... • Answered on Jun 11, 2015
Philips lcd tv problems
There is no such breaker. Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
9/1/2014 6:20:55 AM • Philips... • Answered on Sep 01, 2014
3answers
My philips plasma shows error 63
6/8/2014 7:31:06 PM • Philips... • Answered on Jun 08, 2014
2answers
What are the Vs Vscan Vset and Ve dc voltages
They mean... Vs = usually to do with Volts, usually denoting Vss, or Ground... Can also mean Voltage on the Source of a FET transistor. Vscan, = Scan Voltage. Vset, = Set the Scan Voltage, Ve, = Voltage again usually Vce meaning Positive Volts,. Can also mean Voltage ON the Emitter of a Transistor. But unless one can see the place in the circuit on the schematic, it is hard to tell.
3/9/2014 9:36:23 AM • Philips... • Answered on Mar 09, 2014
0answers
Error Code 63
Be the first to answer 3/6/2014 3:18:20 AM • Philips... • Posted on Mar 06, 2014Be the first to answer
Our Phillips brand flat screen plasma tv will not
I would speculate that you may have faulty capacitors in the power supply section.
11/3/2013 2:06:19 AM • Philips... • Answered on Nov 03, 2013
Philips 42PF9631D 42 in. Plasma Television Logo
164 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
  • Televison & Video
