Texas Instruments TI-83 Plus Calculator Logo
Posted on Sep 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Black Screen When I put in new batteries, the TI-83 screen is black. I tried to raise the contrast, but all that did was change it from solid black to solid navy blue.
Wayne Holden
Level 3:
  • Master 512 Answers
  • Posted on Sep 03, 2009
 Wayne Holden
Master
Level 3:
Answers
512
Questions
Helped
221843
Points
1122
Not for sure but if it has a reset button on the back you probably need to press and hold it for about 10 seconds and see what happens.
2helpful
Why is my TI-83 screen black?
If you cannot see anything on the screen, the contrast may need to
be adjusted.
To darken the screen, press 2nd and release, and then press and
hold up arrow until the display is sufficiently dark.
To lighten the screen, press and release 2nd, and then press and
hold down arrow until the display is sufficiently light
1helpful
Ti 83 plus black screen
Hi
its possible that the flat cable from the M/B to the Display is broken
not much you can do unless you know how to replace the cable
I put more batteries in my ti-83 and the screen is black what do i do
Decrease the screen contrast by pressing and releasing the 2ND key and then pressing and holding the down-arrow key until the screen lightens.
1helpful
My Ti-83 will not turn on, even after putting in new batteries. Occasionally some black will appear on the screen along with some symbols but it then shuts off. Any ideas what is wrong?
Try to increase the contrasts by pressing the key (2nd) and the up arrow until you can see the screen.
Tell me if this fixes the problem or not.
I changed batteries and now the screen is black. How do I fix it?
Hello, it sounds like your contrast needs adjusting. Turn your calculator on; press the "2nd" key and down. The contrast should adjust.
Happy calculating
5helpful
2answers
I replaced the batteries on my TI-83 and now the screen is black
Reduce the contrast.
1. Press [2nd] key and release it
2. Press [DownArrow] and release it
3. Repeat steps 1 and 2 in sequence until screen lightens to your taste.
Hope it helps.
3helpful
The "color" on your screen reset to dark. You can adjust it by pressing "2nd" and the "up" arrow (or "2nd" and "down" arrow) repeatedly.
2helpful
Ti 83 plus small black screen?
try pressing 2nd then hold in down arrow to change the contrast
2helpful
2answers
TI 83 Plus Calculator
You can try to turn the contrast down by pressing 2nd and then hold "down" If the screen does not fix, put new batteries in (including the back up batteries). The problem will be resolved. Hope this helps...
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
