SOURCE: ICEMAKER WILL NOT DUMP ICE
reset the power cool and freezer control buttons.first remove the ice bin then press the power cool and freezer control button for 12 seconds this will set the option which is shown under the fridge control button.set option to 3.wait for 24 hours then you will hear ice dumping in the ice tray.
SOURCE: ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
SOURCE: All display panel lights are blinking,
Bad main control sits on the back of the refrigerator about half way up on the left metal cover. Part number 12920710 double check against model before buying runs $170.
SOURCE: How do I unlock the ice-maker panel?
Press the lock again to unlock. If the second padlock is on, press and hold for 3 seconds to unlock the child lock.
SOURCE: Ice maker in (kenmore )
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
