PCB REPLACED, MCB REPLACED AND GOT THE SAME ISSUE... BACKLIGHTS ARE BRIGHT, AND ALL OF THEM WORK... PLEASE HELP...
SOURCE: KP-57WS500 8 blinks will not power on
High Voltage Splitter Block #8-598-955-32 8 Blinks Call MAT electronics 1-800-628-1118 or Electronix Parts 1-800-223-3205 or you can go to thier websites online.
SOURCE: Sony plasma standby light flashes 8 X, won't stay on
when pluggin power it turns on and immediately move to standby
SOURCE: G1 backlight shows but nothing else
Everything is working fine except the operating system (firmware). A clear case of corrupted firmware. Please get the firmware reinstalled. And you will find that all your problems have vanished. The reason could be a virus or incorrect switching off or powering it on on low battery when the phone switches off on its own. Anything. But reinstalling is the answer.
SOURCE: turns on for 30 sec then goes bright blue and goes
This is blue CRT problem in tv as it is rear projection tv that has three CRTs red-green-blue inside to project color picture on front screen.
Blue CRT (tube) will be replaced to fix the issue and it is job of Pro because lots of adjustments are required after replacement of tube.
Local tv repair shop will help you for that.
Thanks
SOURCE: I have a lcd toshiba
The tv is turning off due to somekind of protection fault. Can you tell me how many times the yellow light flashes in between each pause?
