The first time i tried this hp c7280 printer it came out with a different error, i tried to fix it, and in comes this error?
SOURCE: Uninstall HP image zone 5.3 installation - error installing hp c7280
Did you try an uninstaller program?
Also check out this article about fixing uninstall errors.
SOURCE: I have Windows XP Pro, SP2, Office 2007, and an HP
The problem is you want to have the printer on a fixed IP address. This can be done by reserving the IP for the mac address of the printer in the router OR simpler just set the IP address in the printer.
Change IP settings
The default setting for the IP settings is Automatic, which sets the IP settings
automatically. However, if you are an advanced user, you might want to manually change
the IP address, subnet mask, or the default gateway. To see the IP address and subnet
mask of the HP All-in-One, print a network configuration page from the HP All-in-One.
NOTE: When manually entering an IP Setting, you must already be connected to an
active Network, otherwise the setting will not stay when you exit from the menu.
CAUTION: Be careful when manually assigning an IP address. If you enter an invalid
IP address during the installation, your network components will not be able to connect
with the HP All-in-One.
To change IP settings
1. Press Setup.
2. Press until Network is highlighted, then press OK.
The Network menu appears.
3. Press until Advanced Setup is highlighted, and then press OK.
4. Press until IP Settings is highlighted, and then press OK.
If the HP All-in-One is already connected to a wired network, you are prompted to
confirm that you want to change the IP settings. Press OK.
5. Press until Manual is highlighted, and then press OK.
6. Press to highlight one of the following IP settings, and then press OK.
• IP Address
• Subnet Mask
• Default Gateway
7. Enter your changes, and then press OK to confirm the setting.
SOURCE: c7280 error msg 0xc18a0101
You press # * at the same time...... with the navegation arrows you go up to system configuration, with the arrown you navegate until you see error report...then you clear the error report.....then you turn off the printer...unplug everything from it.. unplug ac adapter from the wall wait 1 minute... then plug power back....turn on printer an Voila...is working
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
SOURCE: My HP C7280 wireless printer is "ofline" how do I
Go to printer folder ( printer and faxes ) right click on the printer and choose " USE PRINTER ONLINE"
Try removing th inks and reinserting them when prompted by the machine . Then with the machine turned on pull the power plug. Wait a couple if minutes then re attach the power cord , press the power button if the machine doesn’t start immediately. Wait for machine to fully power up and follow the prompts on the op panel.
